Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
"check fuel cap"
Old 06-04-2006, 07:49 AM
danflanz's Avatar
Default "check fuel cap"
Got in my car yesterday and it told me to "check fuel cap" I live in NJ so i don't pump my own gas, and this was the first time i've personally even see what my cap looks like. I unscrewed and rescrewed and that didn't do the trick. Any ideas? Thanks
Dan
Old 06-04-2006, 08:32 AM
atruhondagrl's Avatar
Default Re: "check fuel cap" (danflanz)
HuH? I didn't even know there was a message for that. I thought the check engine light comes on when your fuel cap is loose. Odd. Hey, at least you didn't get a check engine light. I got one Thursday night and almost crapped myself. Honda took care of it though.
Old 06-04-2006, 08:41 AM
. L i z's Avatar
3 clicks
Old 06-04-2006, 09:07 AM
danflanz's Avatar
Default Re: "check fuel cap" (. L i z)
k i'll try that, i was doing 2
Old 06-05-2006, 09:18 AM
In a Junkyard near you.
Ross 2.0's Avatar
Copied from November 2005 Honda Service News
NOTE: This article applies to ’05–06 Accords,
’06 Civics, ’05–06 CR-Vs, ’05–06 Elements,
’05–06 Odysseys, ’05–06 Pilots, ’06 Ridgelines,
and ’06 S2000s.
If a vehicle’s fuel fill cap is loose or missing, and
the ECM/PCM detects an EVAP system leak when
it runs the EVAP monitor, the CHECK FUEL CAP
message appears on the information display when
the engine is started. (On ’06 Odyssey Touring
models and future Honda models, it’s the
TIGHTEN FUEL CAP message.) A temporary
DTC is also stored in the ECM/PCM’s memory. If
this happens, there’s really no need for the owner
to bring the vehicle in for service. All he or she
has to do is shut off the engine and make sure the
fuel fill cap is in place and it’s properly tightened
(it’s one or three clicks, depending on what’s
written on the cap).
Although the owner can cycle the message from
the display with the reset button (the actual
button name varies by model), the temporary
DTC that’s setting the message is still there. This
means the message never really goes away. It can
be cycled back with the reset button, and it comes
on again if the ignition switch is cycled or the
engine is restarted. This message keeps coming
back until the EVAP monitor runs again and it
finds no EVAP system leak. This could take several
days, even weeks, depending on how often the
vehicle is driven.
If, when the next EVAP monitor runs, the cap
wasn’t tightened or there’s another EVAP system
leak detected, the MIL comes on and the message
goes off. A permanent DTC is now stored in the
ECM/PCM’s memory. If the owner now tightens
the cap, the MIL should go off after the next EVAP
monitor run, yet, this could still take days or
weeks. If the MIL is still on after that monitor run,
then it’s time to bring the vehicle in for service.
If the vehicle comes into your shop with the fuel
cap message or the MIL on, make sure the fuel fill
cap is in place and properly tightened. Record the
DTC, then clear it with the HDS, and run the EVAP
system function test. If there’s still a problem,
press on with normal troubleshooting
Old 06-05-2006, 03:37 PM
dpao6's Avatar
It resets itself. Mine came up about a month ago one afternoon before I left from work. I drove to the dealership right away and (according to them) even before they hooked the car up to run diagnostics, it turned the message off on its own. Common problem I guess, because in my case, I've been tightening gas caps for over 10 years now, I know I didn't tighten it improperly. Chances are, you guys or the gas attendant didn't either.
Old 06-07-2006, 12:31 PM
06BlackSi #45's Avatar
Yeah mine did the same about a month ago. I got check fuel cap message and it displayed it everytime I turned the car on for 3 days then it went away. And like dpao6 said I know I didnt tighten it improperly. I guess this is a glitch is some of the coupes. Hmm.....
Old 06-08-2006, 09:24 PM
K20Z3Si's Avatar
what does being from jersey and not pumping your own gas have to do with each other???
Old 12-01-2013, 03:47 PM
MintHillBill's Avatar
I think it is illegal to pump you own gas in NJ.... Something done a few years ago which tells you how confident the government is on the typical knowledge of drivers. It may also be a boon to reduce the unemployment since stations have to hire people to pump gas and we all know it doesn't take much skill.
BILL
Old 12-06-2013, 07:07 AM
vladd's Avatar
BILL
Are you drunk/high?
wa8orr
Honda Fit
06-04-2017 07:51 PM
adrnncbn
Honda Fit
05-05-2017 02:59 PM
xi007
01-26-2016 04:27 PM
hrdsktr1988
11
10-20-2009 06:40 PM
Quick Reply: "check fuel cap"
