AT trans slipping / Po730 code - wrong gear ratio after gets warmed up - Honda-Tech
Old 02-17-2007, 01:10 PM   #1
hondarsw's Avatar
Default AT trans slipping / Po730 code - wrong gear ratio after gets warmed up
2001 Civic EX with 130,000 miles on it. Fluid flushed once at 75k. Trans slips excessivly and pulls a P0730 code. Fluid is brnt
Any hope ?
Thanks in advance
P.S. Looks like maybe a trans is in order - if so - DOes anyone have a good line on transmissions. Honda is on back order with no light in sight.
I always thought Hondas were bulletproof and have worked on many over the years - never seen a trans go out at 130k - why me ?
hondarsw is offline   Reply With Quote
Old 02-17-2007, 01:52 PM   #2
Schumacher '10 WDC
Tadehi's Avatar
Default Re: AT trans slipping / Po730 code - wrong gear ratio after gets warmed up (hondarsw)
I have heard so many complaints about the automatic transmission in the '01 civic's its not even funny. Luckily I drive manual. By fluid burnt I assume its black or very dark? I am not a transmission expert but your guess sounds right. You could take it to a transmission repair place, and have them disassemble and reassemble it, but that will cost you loads, sorry. More will chime in don't worry.
PS. Welcome
Tadehi is offline   Reply With Quote
Old 02-17-2007, 02:46 PM   #3
Curiouz_G's Avatar
the auto trannies in the 7thgen's were one of the crappiest ever made by honda if not THE crappiest
Curiouz_G is offline   Reply With Quote
2002 Accord F23 - Transmission Issues ZekeZG Honda Accord (1990 - 2002) 1 04-05-2016 02:24 PM
1998 honda civic hatch. auto trans issue (solved) Lildj2983 Honda Civic / Del Sol (1992 - 2000) 6 08-02-2015 02:08 AM
2006 Accord Trans slipping...is it toast? STRSHP Transmission & Drivetrain 10 01-15-2014 08:21 AM
Changing transmission fluid St3v3 Honda Accord (1990 - 2002) 10 02-11-2007 06:09 PM
95 GSR Hydro Trans F.S. NJ/PA/DE/MD <-------------- slooogsr For Sale 68 05-31-2004 08:46 AM
Tags
01, accord, acura, acuracodepo730, auto, automatic, civic, code, fluid, honda, p0730, po730, repair, slipping, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
