Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
civic turbo psi
Old 02-16-2007, 10:59 PM
lifes_simple's Avatar
Default civic turbo psi
i drive an 05 civic lx and i have a T25 turbo at home for it and planning on putting it in in the summer, whats the most psi you think i can put on it w/ out it destryoing my engine ?
Old 02-16-2007, 11:48 PM
Vantage's Avatar
8-9 is probably max id go. Maybe 10 if u spend a good deal tuning it.
Old 02-17-2007, 12:24 AM
AR_motorsports's Avatar
Default Re: (Vantage)
I am planning on running mine at 5.8 (.4bar spring) I figure people run these engines at 7-8 stock without alot of issues so 5.8 should make a good daily drive without a constant worry and still be hella fun to play with
Old 02-17-2007, 06:59 AM
Default Re: (AR_motorsports)
okay ill prpably try the 5.8. but lets say i dont have mone for a boost contoller yet and i install the turbo, what psi would it be at ? and how would i know ?
Old 02-17-2007, 10:15 AM
Default Re: (lifes_simple)
if you are not using a bost controler the your pressure is determined by the spring that you are using in your wastegate 5.8 psi = .4bar spring
eulises08
09-09-2009 09:39 AM
88 yellow crx
02-01-2008 11:45 AM
t-powersi
04-29-2007 08:02 AM
Makdaddynuge
04-19-2006 12:00 PM
frostcivic
08-28-2004 02:19 PM
Quick Reply: civic turbo psi
