Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Timing Belt replacment Now p0420 code
Old 02-08-2016, 10:41 AM
El0124's Avatar
Icon4 Timing Belt replacment Now p0420 code
I just had my timing Belt & water pump replaced on my 03 civic now the mechanic says the check engine code is the p0420 which was not on before this can this work trigger this code and what should i do ive noticed when i go to start the car sometimes it hesitates a little bit
Old 02-08-2016, 05:29 PM
Falloutkid90's Avatar
Catalytic converter below threshold i think. Im pretty sure it means your rear o2 sensor needs to be replaced. 40 or 50 bucks for the part im pretty sure you can do it yourself.
Old 02-08-2016, 05:32 PM
whitesihatch's Avatar
Default Re: Timing Belt replacment Now p0420 code
I installed a spark plug defouler for the 2nd o2 sensor $8 dollar fix. p0420 Cel has been off for 6,000 miles and counting after the install. No drivability issues, still get 34-38mpg.
The catalyst below threshold code appears when the catalytic converter is below 95% efficiency, hell there is days when Im below 95% efficiency, and things work out just fine.
tautog
04-02-2017 01:51 PM
SPORT INJECTION
22
05-30-2006 04:15 PM
Bh8teen
08-31-2005 09:26 PM
civic_dork
07-03-2005 07:40 AM
padraf
07-14-2004 02:49 PM
Quick Reply: Timing Belt replacment Now p0420 code
