Tachometer test signal? - Honda-Tech
Old 01-01-2011, 02:21 PM   #1
Default Tachometer test signal?
Hello this is for a 2001 Civic. This is kind of a technical question, but I need to know what the pulse train at the tachometer test connector looks like. In other words, what is the pulse voltage, pulse rate and pulse width, that kind of thing. My car currently doesn't have an engine, or I would just look at the signal with an oscilloscope. Probably not too many people know this but I thought I would give it a try - can anybody help?
jwriter is offline   Reply With Quote
Old 01-01-2011, 05:53 PM   #2
Default Re: Tachometer test signal?
It pulses from 0v to around 5v. Width of the pulse depends on the vehicle speed.
lazlong is offline   Reply With Quote
Old 01-01-2011, 09:19 PM   #3
Thank you! I assume you mean engine speed. In other words, at 0 rpm the width of the pulse is vary narrow and at 6000 rpm it is much wider?
Old 01-02-2011, 05:39 PM   #4
fiveten's Avatar
The tach is driven by the pcm through serial communication. There is no tach pulse to measure. You can tap into the communication line with your dso and get a serial pattern but you wont know what it is saying.
fiveten is offline   Reply With Quote
Old 01-03-2011, 03:05 AM   #5
Guess I should have been more specific. The VSS signal pulses from 0v- 5v.
Old 12-31-2013, 11:48 AM   #6
can you tell me how we do the wiring ?
gabrielsousa is offline   Reply With Quote
voltage dropping why? 94 integra estefi357 Tech / Misc 10 04-29-2016 09:29 PM
Fuel bypass and injector pulse questions BseriesEKhatch Tech / Misc 1 02-28-2014 06:11 PM
Need help with CKF wiring Silver_Integra_ Acura Integra 9 04-20-2012 11:21 PM
2008 Civic SRS code 2-7 paulb3456 Honda Civic (2006 - 2015) 2 03-20-2011 09:47 PM
Can you use a test light to test injector pulse? psycho.chicken Honda CRX / EF Civic (1988 - 1991) 4 07-17-2006 01:20 PM
Tags
06, civic, connector, honda, location, pulse, pulses, rate, rpm, signal, tach, tachometer, tachommter, tackometer, test, tester
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
