Suspension noise? - Honda-Tech
Suspension noise?
Old 02-12-2009, 09:49 AM   #1
_illmatic_'s Avatar
Default Suspension noise?
Hey what up HT, I droped my car 2 inches with Tokico Blues and Neuspeed springs. I've been on this step up for about three months now, and all of a sudden now when I turn my wheel all the way to the left or right, as if I'm trying to back out of a parking space or my driveway it makes a little "poping/bumping" sound. Its not associated with accleration or anything, just when I turn the steering wheel all the way. Its also only the front left side. Any help will be appreacted. Thanks!
_illmatic_ is offline   Reply With Quote
Old 02-12-2009, 09:54 AM   #2
Function>Fashion
Harlowe's Avatar
Default Re: Suspension noise?
Sounds like coil binding. It's common with springs. Maybe reseat your springs, might help.
Harlowe is offline   Reply With Quote
Old 02-12-2009, 10:08 AM   #3
_illmatic_'s Avatar
So you reccommend I should reseat the springs in the strut?
Old 02-12-2009, 10:11 AM   #4
Function>Fashion
Harlowe's Avatar
Hmm dunno, maybe. I had this when I had springs, I never did anything about it though.
Old 02-12-2009, 10:13 AM   #5
_illmatic_'s Avatar
Didn't mess anything up? Just kept making that irritating sound?
Old 02-12-2009, 01:48 PM   #6
EM2_PLo's Avatar
I had the same problem you did when i lowered my car with skunk 2's on tokico blues ...Your strut bearings are probably busted... replace them and the noise will go away ... it worked on mine
http://www.autopartsplace.com/carpar...t-Bearing.html
This strut bearing fits the factory top hat perfectly
EM2_PLo is offline   Reply With Quote
Old 02-14-2009, 03:17 PM   #7
_illmatic_'s Avatar
Thanks homie!
Old 03-12-2009, 04:02 PM   #8
gras's Avatar
hey did the noise go away?
I'm getting the same problem. My mechanic said a part of the steering rack which is a mount is busted.
Anyone can elaborate?
I dropped my car about 8 months aback with tein s tech.
gras is offline   Reply With Quote
Old 03-12-2009, 08:40 PM   #9
01_civic's Avatar
you probably just didn't align it right. just take apart/put everything back together and line up the arrows and it should go away
01_civic is offline   Reply With Quote
Old 03-12-2009, 10:22 PM   #10
DynastyRacer22's Avatar
the people at the tire place replaced my strut bearings for me already and the noise is still there sometimes i think you do have to loosen up the bolts on the top and jack the car up and realign it like how 01 civic said
DynastyRacer22 is offline   Reply With Quote
Old 03-12-2009, 10:33 PM   #11
portaman03's Avatar
Does it make the noise while the car is turning in motion or standing still? In motion, might be your axles popping.
portaman03 is offline   Reply With Quote
Old 03-13-2009, 05:22 PM   #12
gras's Avatar
It makes the noise when car is in motion and sometimes when at stand still.
Also the suspension guy said that my F and R engine mounts needs changing and the 2 big front cradle bushings.
Also the bushing in the steering rack needs changing.
Anyone can elabotate?
Old 03-13-2009, 05:55 PM   #13
likeahstone's Avatar
sounds like your "suspension guy" is trying to make a little doe
likeahstone is offline   Reply With Quote
Old 03-14-2009, 01:06 AM   #14
tunerkid7's Avatar
i just took mine apart and put it back together and it went away, every once in a while it will make noises or pop, but after a few minuets they go away
tunerkid7 is offline   Reply With Quote
Old 03-14-2009, 03:17 AM   #15
thisguyhere's Avatar
Well, I have a pretty similiar situation with the popping noise while I'm driving. I'm pretty sure it's my axle (speedbump).. because I bottom out everywhere ..and I ruptured my cvboot..Hopefully after getting that issue fix the popping may go away.
thisguyhere is offline   Reply With Quote
Old 03-14-2009, 11:01 AM   #16
Jstans84's Avatar
Quote:
Yeah you might want to get that fixed. Assuming that it is one of your front axle's you are talking about it is easy as hell to replace. I tore my CV boot when I was putting in my TEINs so I just replaced the axle. It was like between 50 and 60 bucks plus a $30 core fee at autozone than you get the $30 back when you bring them your old one. Or you can just pick up a CV Quick Boot Kit for $20 and just repair the boot. But that is your call.
Jstans84 is offline   Reply With Quote
Old 03-16-2009, 09:19 PM   #17
01_civic's Avatar
before u do anything and pay, just take it apart and see if it is properly aligned. if it is and it still makes that noise, then get it fixed. because i had this sound when turning and going over bumps, but after i properly aligned it, the sound went away
Car Shuts off when steering wheels is all the way left/right in neutral KashMillien Honda Prelude 1 11-22-2015 08:11 PM
RHD conversion. Car turns one way but not the other? PLEASE HELP CAN'T MAKE LEFT TURNS! TREESnoseeds787 Honda Civic / Del Sol (1992 - 2000) 6 11-05-2008 05:15 PM
knocking noise.. from wheel... axels? wtf 1_slow_crx Tech / Misc 8 09-10-2006 09:29 PM
weird steering issues menappi Honda CRX / EF Civic (1988 - 1991) 3 01-13-2004 01:35 AM
Car makes a metalic scratching noise when turning left. Possible fixes? keys Acura Integra 8 05-11-2003 09:53 PM
Tags
03, 20012005, 2004, accord, civic, cvboot, honda, making, noise, popping, replace, sound, springs, suspension, turning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
