Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
what is the best full synthetic oil ????????????
Old 03-14-2009, 02:31 PM
lowlife9's Avatar
Default what is the best full synthetic oil ????????????
i want to switch to full synthetic oil what is the best kind of oil and the best synthetic fiber oil filter 04 dx 116,000 miles on it i was leaning towards amisoil but i can't find it anywhere .
Old 03-14-2009, 03:40 PM
TOO MUCH TORQUE's Avatar
Default Re: what is the best full synthetic oil ????????????
castrol syntec euro formula with mobil 1 filter
Old 03-14-2009, 03:54 PM
redciv4u's Avatar
Royal Purple
Old 03-14-2009, 04:04 PM
be professional
Targa250R's Avatar
Originally Posted by TOO MUCH TORQUE
castrol gtx euro formula with mobil 1 filter
GTX is natural oil. Castrol's synthetic is called Syntec.
Paul-R's Avatar
I put the oil the dealerships recommend .
Old 03-14-2009, 04:06 PM
WhyTry?'s Avatar
royal purple hands down
Old 03-14-2009, 04:34 PM
ss8EM2's Avatar
In my experience with Synthetic, I really liked Royal Purple. But, if you have worn rings synthetic will bypass easier than conventional due to smaller molecules and lower viscosity at high temperatures. Trust me, with that many miles you'll be adding oil with synthetic. I kept using synthetic oil and wondering why I kept adding 1/2 qt every 1,000 miles until one of my friends told me the same thing and sure enough now that I am using conventional again no problems.
Old 03-14-2009, 06:27 PM
lowlife9's Avatar
well would you have that problem with a blend or maybe a thicker viscosity synthetic ????? i thought synthetic was more stable at higher temperatures
Old 03-14-2009, 06:58 PM
be professional
Targa250R's Avatar
Synthetic doesn't break down as easily with high oil temperatures, but 1) that has nothing to do with burn-off and 2) it doesn't really matter in a low-revving naturally aspirated daily driven car, which won't see excessive oil temps under most conditions.
Synthetics tend to burn off faster than natural oil of the same viscosity in most cases (Mobil 1 in particular is notorious for it), so if your car burns any significant amount of oil, it's a bit pointless to switch to synthetic as you're just going to end up burning off more expensive oil at an even faster rate.
The only real advantage to using synthetic oil in a mild daily driver is extended drain intervals. Unless you're changing oil at 8,000+ mile intervals or using forced induction and seeing oil temps over 250F constantly, synthetic is really just a waste of money.
Plenty of cars have run hundreds of thousands of miles on conventional oil, and I've never seen a Honda engine failure that could have specifically been avoided by using synthetics.
Old 03-14-2009, 07:05 PM
whoops thats that i meant.
OP go with the Castrol Syntec EUro Formula. The viscosity on those is 0w-30.
Old 03-14-2009, 07:33 PM
ejLday's Avatar
would you be able to clarify the claims I have heard that if you use synthetic you should not switch back and forth to conventional?
Old 03-14-2009, 07:40 PM
be professional
Targa250R's Avatar
It doesn't matter one bit with modern oils and engines. Switch back and forth as freely as you'd like.
Old 03-14-2009, 08:17 PM
ejLday's Avatar
sweet thx for the info, that's a relief. I have been wasting my money on sythetic for some time now, and being as how i change every 3k anyway its pretty pointless. As far as filters I use the mobil 1 filter, any cheaper recommendations?
Old 03-14-2009, 08:38 PM
hondateg91's Avatar
I used Castrol GTX high mileage in my old DA, but just changed to Castrol Syntec in my civic with bosch filters.
Old 03-15-2009, 06:56 AM
JamesL's Avatar
Ive had great luck with Amsoil in the past. My D17 held up great after 4 years of beating on it on the track. And I mean beating.
Currently running Amsoil in my K20... but Im about to try Brad Penn Racing oil. It is a semi-synthetic, but I have read nothing but fantastic reviews about it. It is the green oil
Old 03-15-2009, 07:36 AM
kulo's Avatar
Rp
Old 03-15-2009, 11:53 AM
not2fst's Avatar
I run Ford Motorcraft synthetic. It has been proven to protect as well as Mobil 1, and for 1/3 of the price. Its not like we are protecting big horsepower, big dollar cars.
Old 03-15-2009, 02:14 PM
dirtymicrophone's Avatar
Royal Purple 5W-20 with Honda filter does it for me.
Old 03-15-2009, 02:55 PM
lowlife9's Avatar
ok well i couldn't find amsoil anywhere which sucks because the research i did put them on top so i got royal purple and a glass fiber royal purple filter .which should be fine till i get my hands on some amsoil.and i also threw in a magnetic drain plug for the hell of it.
Old 03-16-2009, 06:36 AM
03EXHondaOKC's Avatar
Mobil 1, use it in all my vehicles.
Old 03-16-2009, 09:46 AM
batac_boy's Avatar
Red Line Synthetic Oil!
Old 03-16-2009, 08:57 PM
New User
pwnusmaximus's Avatar
I use Mobil1 and have done so for as long as I remember, regardless of mileage.
kabayo73
Honda Civic (2006 - 2015)
11-01-2017 03:14 AM
deefl44
Honda CR-V & Element
03-08-2015 01:57 AM
mxracer420
13
04-08-2009 05:54 PM
climb_on
07-15-2007 04:05 PM
Kiniku Chunks!!!
08-24-2006 12:39 PM
Quick Reply: what is the best full synthetic oil ????????????
