squeaky clutch - Honda-Tech
squeaky clutch
Old 07-29-2011, 05:17 PM   #1
Default squeaky clutch
Hello, i am new to the forum. I have an 01 honda civic dx with a 5 speed manual trans. I am having a problem that i am having trouble diagnosing. When i release or press my clutch pedal, i hear a loud squeaking noise. Initially i thought it was the pedal linkage so i lubed it and this did not fix it. Upon looking further into it, i learned it is not coming from inside the cabin but rather the slave cylinder area. Could a slave cylinder make this noise? Should i replace it? Or is it more likely the fork that actuates the throw out bearing? Any assistance would be much appriciated
Thanks,
Josh
jsohn is offline   Reply With Quote
Old 07-29-2011, 07:25 PM   #2
It Wasn't Me's Avatar
Default Re: squeaky clutch
It's more than likely the joint where the slave cylinder meets the release fork.
You'll need to pry the rubber boot back (away from the housing, towards the slave cylinder) and lube the joint.
I used white lithium grease on mine. Haven't had the noise return in some time now.
It Wasn't Me is offline   Reply With Quote
Old 08-01-2011, 12:23 PM   #3
devonkyle77's Avatar
i lubed that and mine is still squeaking.
devonkyle77 is offline   Reply With Quote
Old 08-01-2011, 12:44 PM   #4
Quote:
If it's squeaking in the same area shown in the photo, try applying a more generous amount lube.
If it's squeaking near the clutch fluid reservoir, it's probably the master cylinder. There was a TSB for it.
From the FAQ's...
Clutch Squeak problem, Master/Slave Cylinders replaced... still squeak.. Help? ychanus1 Acura Integra Type-R 8 08-06-2013 10:04 AM
Need help, Dead clutch pedal Born2Build Honda Accord (1990 - 2002) 1 05-22-2011 07:02 PM
Fs: 92-00 civic 5 speed swap SprayinCX For Sale 1 07-12-2006 11:39 AM
NEW CLUTCH SLAVE-HELP? LOC714 Honda Prelude 6 10-17-2004 11:15 AM
Creaking noise from clutch?? replaced master, still noise!! xsnrgsr Acura Integra 9 07-13-2003 09:23 PM
Tags
2001, civic, clutch, cylinder, fork, honda, hondatech, integra, master, noise, pedal, rsx, slave, squaky, squeaking, squeaky, squeeky
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
