RPM Jumps after head gasket replacement - Honda-Tech
Old 08-27-2013, 11:03 AM   #1
EM2 Charlay's Avatar
Default RPM Jumps after head gasket replacement
Hey guys,
I have been searching and trying different things but I am losing patience. I have a 2005 Honda civic. I just replaced the head gasket due to overheating. I didn't have any idle problems before.
When I start the car the RPMs jumps up and down constantly while in park. I have checked and cleaned the idle control valve but it has the same issue.
I am going to bleed the coolant again tonight and see what happens but I can't figure out what happened.
Any suggestions?
EM2 Charlay is offline   Reply With Quote
Old 08-27-2013, 11:39 AM   #2
Default Re: RPM Jumps after head gasket replacement
Sounds like a vacuum leak. You check all the piping/hoses that were unplugged? You check the torque on the manifolds? Also, how do the seals to the injectors look?
MartyZ is offline   Reply With Quote
Old 09-03-2013, 10:10 AM   #3
I checked the injectors and seals. Sat them in properly. Checked my houses but none look to be leaking. The car is doing something a little different now. It will idle semi normal on startup. After a minute or so it will start acting like it is going to die. When I rev it, the rpm's will start jumping again just like before. I am going to pull the manifold off and recheck everything one more time. I am going to try and recheck the torque specs on the rocker arm assembly etc. and make sure everything is put on correctly.
Old 09-03-2013, 06:32 PM   #4
Djratrap's Avatar
I agree it sounds like a vacuum leak.
Djratrap is offline   Reply With Quote
93 Civic - Shaking and Tach jumps at 1000 RPM CaptRexKramer Honda Civic / Del Sol (1992 - 2000) 6 11-10-2014 02:13 PM
Replaced VSS and still doing the same thing! hsmith52 Honda Civic (2001 - 2005) 0 10-06-2013 11:48 PM
Jumping Idle, tried everything, HELP! jdm.I.am Honda Civic / Del Sol (1992 - 2000) 30 03-29-2011 05:52 AM
Jumping idle? jmccalip Honda Accord (1990 - 2002) 3 05-25-2008 07:52 PM
fluctuating idle at start up MATiC Acura Integra 7 12-02-2006 08:26 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
