Proper Torque for Wheel Lugs? (searched) - Honda-Tech
Old 11-03-2008, 09:33 AM   #1
GriFFIthS's Avatar
Default Proper Torque for Wheel Lugs? (searched)
so i've been searching around and i cant seem to find the proper Torque specs for my 01 civic dx, i dont have my manual so i cant check that, i've been told its 80 ft/lbs, also have been told that its 90ft/lbs.
can someone please let me know the actual spec, also if possible i need to get a socket for my torque wrench but i dont know the size, been told its 5/8 inch that i need.
any help would be great, thanks
GriFFIthS is offline   Reply With Quote
Old 11-03-2008, 09:53 AM   #2
Sanji
toyomatt84's Avatar
80 lb/ft (110 Nm)
I believe the standard lug nut requires a 21mm socket.
toyomatt84 is offline   Reply With Quote
Old 11-03-2008, 10:01 AM   #3
GriFFIthS's Avatar
Thank you, thats exactly what i needed.
cheers
Old 11-03-2008, 10:44 AM   #4
Default Re: (toyomatt84)
Quote:
Its a 19mm socket.
Boilermaker1 is offline   Reply With Quote
Old 11-03-2008, 12:55 PM   #5
Sanji
toyomatt84's Avatar
Default Re: (Boilermaker1)
Quote:
Originally Posted by Boilermaker1
Its a 19mm socket.
I couldn't remember the number, my mistake.
I've never had a set of OEM lug nuts for my car anyways.
Old 11-11-2008, 10:41 PM   #6
ejLday's Avatar
Default Re: Proper Torque for Wheel Lugs? (GriFFIthS)
80 ft/lb
ejLday is offline   Reply With Quote
Old 11-12-2008, 05:03 PM   #7
Default Re: Proper Torque for Wheel Lugs? (ejLday)
ok what's really good to use a Torque stick or a Torque wrench?
Modified by batac_boy at 5:16 PM 11/12/2008
batac_boy is offline   Reply With Quote
Old 11-12-2008, 06:52 PM   #8
Sanji
toyomatt84's Avatar
Default Re: Proper Torque for Wheel Lugs? (batac_boy)
Torque wrench.
Old 11-12-2008, 07:01 PM   #9
Function>Fashion
Harlowe's Avatar
Default FV-QR
Don't forget anti-seize!
I used to break studs all the time from over-tightening my lugs, then a good friend of mine (fventura03 ) taught me to tighten them as much as you can with your hands, if you don't have a torque wrench. Don't stand on the tire iron and stuff, hahaha.
Harlowe is offline   Reply With Quote
Old 11-13-2008, 11:37 PM   #10
FijiBlueHero's Avatar
Can toyomatt84 or anybody confirm on the method posted by Harlowe. I want to do a tire rotation and I just want to know if that method is safe so i can do it. The only tool I have is the lug wrench that came with the jack in the Car. Thank you .
FijiBlueHero is offline   Reply With Quote
Old 11-13-2008, 11:40 PM   #11
Sanji
toyomatt84's Avatar
Default Re: (FijiBlueHero)
Quote:
I'll confirm his method. Ideally, you'd want a torque wrench, but anti-seize and a tire iron will work nicely. You do not need to put all your weight into tightening the lug nuts. Just simple arm strength will suffice.
FAQ B series torque specs BlueShadow Honda CRX / EF Civic (1988 - 1991) 54 09-17-2015 10:39 AM
Damper fork, which torque 1990IntegraLS Acura Integra 6 08-15-2015 07:29 AM
LS Cam Holder Bolts Torque ???? Xscort All Motor / Naturally Aspirated 8 01-19-2010 12:11 PM
Over-torqued bolts & nuts...how bad? Tim2179 Acura Integra 4 08-28-2005 07:02 PM
Torque spec for spark plugs? ITRFetish2000 Acura Integra Type-R 12 05-09-2004 07:47 PM
Tags
2001, 2006, 80, audi, civic, honda, lb, lug, lugs, odyssey, size, socket, spec, torque, wheel, wheels, wrench
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
