Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Problems with my door lock?
Old 02-22-2012, 07:35 AM
jamesonc's Avatar
Default Problems with my door lock?
I searched and couldn't find anything on it guys, so I have power locks and windows in my car, and when you lock the locks, they all lock except the drivers door. I've seen it work once. But you can lock the door from the outside with the key. Any suggestions?
Old 02-22-2012, 11:11 AM
Plead da Fif
It Wasn't Me's Avatar
Default Re: Problems with my door lock?
Actuator. It's either disconnected or bad and needs to be replaced.
Old 02-22-2012, 02:55 PM
1clean01's Avatar
D.I.Y
http://www.civicforums.com/forums/10...-actuator.html
Old 02-22-2012, 03:57 PM
thejackal0398's Avatar
I have this same problem. I read online on 7th gen site that if you listen in the door and you hear it clicking that the actuator is still good? Mine still makes noise which makes me believe that it still works. Am I wrong? How would i check if it is still good?
Old 02-22-2012, 04:39 PM
Plead da Fif
The actuator may still make some noise but is too weak to lock/unlock the door. Mine does the same thing, but every once in a great while the power door lock will actually work.
It just doesn't bother me enough to change the actuator. I don't mind using the key.
Old 02-22-2012, 07:47 PM
jamesonc's Avatar
I'll tell you how retarded I can be sometimes guys. It's a safety thing, the power lock won't lock when the driver's door is open. If you're in the car and all the doors are shut, all 4 doors lock. Lol.
Old 02-23-2012, 09:32 AM
I wouldnt mind using my key if the key lock actually worked. I put keyless entry to bypass the problem but now the damn thing doesnt unlock. Ill try and replace actuator. Thanks Guys
eppoh
07-16-2005 08:11 PM
Eggman
21
10-15-2004 12:20 PM
phuc
09-21-2004 02:18 PM
fe519
11-03-2002 08:31 PM
TypeR0207
06-10-2002 12:58 PM
Quick Reply: Problems with my door lock?
