P1705 PLEASE HELP! - Honda-Tech
P1705 PLEASE HELP!
Old 05-06-2011, 10:08 AM   #1
CivicSweetie01's Avatar
Icon3 P1705 PLEASE HELP!
My car was acting just fine.
Then my check engine light comes on.
My car was in Drive, and the d starts blinking, but now the D3 light is on as if it was in d3.
I stop the car and put it in park, and the D is still blinking.
New tranny was put in it before I bought the car 10,000 miles ago.
Any suggestions on what I need to do?
I can't ever get honda parts around here, so I am going to have to order them somewhere.
PLEASE give me GOOD advice on what I should do.
CivicSweetie01 is offline   Reply With Quote
Old 05-06-2011, 10:26 AM   #2
Default Re: P1705 PLEASE HELP!
P1705= transmission range switch circuit malfunction.
Post #11: http://honda-tech.com/showthread.php?p=43071329
lazlong is offline   Reply With Quote
Old 05-06-2011, 11:12 AM   #3
I don't have technology to test it.
I don't have the money for Honda to test it.
I'm sure I have money for the parts, but where to get it?
Ahhh. this is just not my week >.< Thanks for your post
Old 05-06-2011, 11:48 AM   #4
Test to see whether it's the switch simply by unhooking the connector and turning on the ignition. But if you want to just buy the switch: http://www.hondapartscheap.com/southbay/jsp/home.jsp Look under "AT RIGHT SIDE COVER ".
*Edited 'cause I was probably a little harsh.
Old 05-06-2011, 04:04 PM   #5
okay thanks, and yes i have been searching all day on this. just a lot of cluster. thank you again.
Old 05-18-2011, 09:33 AM   #6
Icon6 Re: P1705 PLEASE HELP!
It was my neutral safety switch.
I got that put on.
Then, found out that the smoke coming from my hood wasnt the thermostat housing that I had changed, but a crack in my radiator. Now, waiting on the radiator to get here to change that out.
When I looked on carfax before i got the car, nothing showed up. I checked it the other day. and there is 24 reports on my car... yipes... too bad i can't afford to find out what they all say... lol.
I know now, that is had been in a wreck, because when I was vaccuming it out i found glass in the seat. and my boyfriend pointed out a spot in the door that they didn't repaint....
So many problems... and now, i also found that the plastic cover in my cam shaft is leaking oil?? what is this and how can I fix it if anyone knows.
Old 05-18-2011, 10:10 AM   #7
It Wasn't Me's Avatar
Quote:
Are you referring to the plastic end plug? It's easy to replace, but it's best to remove the valve cover and work from inside.
I've heard of people just prying the old one out with a screwdriver, but you run the risk of braking one of the plug tabs off and having fall into the head while removing the old one.
Also, make sure to apply a little bit of oil (preferably fresh) to the seal before you install the plug.
It Wasn't Me is offline   Reply With Quote
Old 05-18-2011, 09:33 PM   #8
it was the neutral safety switch the plug. I got the part and put it on. Light went off. That part is fine.
Old 05-18-2011, 09:38 PM   #9
You said, in your last post..
That's what I was asking about.
What "plastic cover" are you talking about? There is no plastic cover for the camshaft, but there is a plastic end plug / seal.
Old 05-18-2011, 09:45 PM   #10
yeah. it's at the end. so i guess it is the plugs. they are plastic. sorry. I'm new to all of this... i'm learning a lot as i go. bear with me.
Old 05-18-2011, 09:47 PM   #11
No problem. It happens.
Old 05-18-2011, 09:50 PM   #12
I will post more when I figure some more out on everything. It got late, I'm hoping this all works out in the end.... Single mother on very small budget... Hard Hard Hard dealing with a car that I can't afford to take to the shop >.<
Thanks for your nice and helpful posts.
Old 05-18-2011, 10:08 PM   #13
@ CivicSweetie: If you can, pictures always help.
Old 07-15-2011, 11:20 AM   #14
Icon2 Re: P1705 PLEASE HELP!
i had the same problem on my honda accord all if u just put a security sistem in your car have them disconect the kill switch relay and reset the ecu and it will all go away
Last edited by honda v6; 07-15-2011 at 11:23 AM. Reason: forgot to anwer the question
honda v6 is offline   Reply With Quote
05 V6 Accord blinking "D" light v6veggie Honda Accord & Crosstour (2003 - Current) 9 08-16-2014 03:35 AM
the "d' is blinking f88bonilla Honda Civic / Del Sol (1992 - 2000) 18 08-09-2011 11:13 AM
Can somebody plz help me with this TCU code? LS_teggy Acura Integra 0 07-11-2010 10:53 AM
code 17 after clutch swap Chrisrey86 Honda CRX / EF Civic (1988 - 1991) 1 05-13-2007 11:16 AM
D4 LIGHT BLINKING 94 ACCORD 4DRPIMPIN Honda Accord (1990 - 2002) 6 09-26-2003 01:16 PM
Tags
2001, 2005, accord, acura, circuit, civic, d17, d3, fix, honda, location, p1705, range, short, switch, tl, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
