no adjusting valves?
I was going to adjust my valves on my 04 civic vp but the sticker on the hood says no adjustments needed or whatever.....are mine non adjustable?
Re: no adjusting valves?
no specs on the hood.. you can ask the dealership if they could provide you with the specs. sometimes they'll just make a copy for you or print them out. the adjustment should be check or done around every 30k miles when you are servicing the valve cover gasket. or so i've been told. but its not always necessary because sometimes it is fine and nothing needs to be done.
SPOON_BeIgHtEeNsEe
06-21-2003 08:58 PM
