Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
need help on obd 2 code problem on my 02 civic coupe
Old 02-20-2012, 08:26 AM
suimengher's Avatar
Default need help on obd 2 code problem on my 02 civic coupe
i switch my 02 sensor out and put on a new one but my check engine light keeps coming on every 15-18 miles..the code read p0138..not sure what is wrong since i fix the problem..any idea on what else can be wrong?...thanks.
Old 02-20-2012, 08:40 AM
EK9
Dc4LsTeG's Avatar
Default Re: need help on obd 2 code problem on my 02 civic coupe
Did you try resetting the ecu
Old 02-20-2012, 08:42 AM
suimengher's Avatar
no i havnt try resetting the ecu ..im a rookie to this and im just pulling out my hair trying to look over all this...but if you dont mind how do you reset ur ecu?..
thanks
Old 02-20-2012, 08:44 AM
EK9
Dc4LsTeG's Avatar
Disconnect the battery for a couple seconds the reconnect it. Then see if your code comes back
Old 02-20-2012, 08:45 AM
suimengher's Avatar
ok i did take off the battery and the check engine would come back on within 15-18 miles..at this point im at lost..
i did that bout 3 times alrdy and yet it comes back on with the same code..p0138..but it has the new 02 sensor on so my only guess is the wiring bad or something?..
Old 02-20-2012, 10:27 AM
eviee1973's Avatar
For your secondary sensor, did you actually install the proper oem secondary plug in sensor? Or have you put in an incorrect aftermarket sensor, or a make fit universal aftermarket sensor where you have to reuse your existing sensor plug in harness?
Old 02-20-2012, 07:24 PM
suimengher's Avatar
i put in the right one from napa auto for my car...but come to find out theres a gap between the bottom of my header and the muffler pipe switch its connects with two srcews..
Pothole987
08-23-2011 08:22 PM
Carbcivic
04-02-2008 03:28 PM
Dc_Ek
08-09-2006 08:28 AM
Nerv2g
08-10-2003 08:42 PM
Quick Reply: need help on obd 2 code problem on my 02 civic coupe
