My keyless entry remote not working - Honda-Tech
Old 11-17-2006, 12:29 AM   #1
bjdealer's Avatar
Default My keyless entry remote not working
The keyless entry remote for my 2001 Civic EX is not working. When I press the lock or unlock buttons the lights flash, but the doors do not unlock. Also, to lock the drivers door, I have to pull out the handle and then push the lock down. I have replaced the battery in the remote, and the fuse under the hood, but it still doesn't work. Any help out there for this "semi-mechanically inclined" woman?
bjdealer is offline   Reply With Quote
Old 11-17-2006, 01:37 AM   #2
JDM_ESK1's Avatar
when you are inside the car, and flip the Lock Switch by the door handle does it lock? If not and you've checked all the fuses under ur dash and under the hood... it may be the actual lock unit that may be defective.
Have you had any other types of service done recently on the vehicle? If so maybe something was disconnected by accident.
Usually its a fuse labelled "Back-up" under the hood.
JDM_ESK1 is offline   Reply With Quote
Old 11-17-2006, 07:02 AM   #3
yamahaSHO's Avatar
Default Re: My keyless entry remote not working (bjdealer)
I had the same thing happen. I bought two remotes on eBay and one of them just stopped working. The light still lit up, but nothing happened. I then tried to reprogram for the key fob and no luck. I went and got my other key fob and it works fine. I'm going to replace the battery to see if when it runs low, maybe it only has enough power to light up the red flasher.
If it is indeed broken, just buy one on eBay and program it yourself. It takes all of 20 seconds.
yamahaSHO is offline   Reply With Quote
Old 11-17-2006, 10:18 AM   #4
24.224.233.247
Default Re: My keyless entry remote not working (yamahaSHO)
programming maybe yamo. lost it perhaps. never encountered this prolem yet.
cranny is offline   Reply With Quote
Aftermarket Keyless Entry Help NMBB6 Audio / Security / Video 2 06-23-2011 10:43 AM
door unlock problem jdmwojo Honda Civic / Del Sol (1992 - 2000) 10 11-19-2009 03:06 AM
Problem With Keyless Entry and Driver Door xtreme 2 Acura TSX 2 03-23-2008 09:49 PM
Keyless Remote not engaging actuators extrmeboost Audio / Security / Video 6 02-04-2006 12:57 PM
keyless entry problem... civic-cpe Audio / Security / Video 6 03-06-2003 07:50 PM
Tags
2001, 96, accident, acura, battery, civic, entry, fob, honda, key, keyless, problem, remote, replace, stopped, tl, work, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
