Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Moisture In Headlight
Old 01-20-2007, 08:48 AM
jersex's Avatar
Default Moisture In Headlight
I have an 02 Civic EX. Yesterday, I noticed that the driver side headlight has condensation or moisture inside the headlight on the lens. Anyone know if I can repair this or should I just start searching Ebay for a new headlight? Thanks!
Old 01-20-2007, 09:40 AM
Boost_Junkie's Avatar
is it oem headlight or did you open it to blackhouse?
regardless when that happens i just take out a light bulb and hair dry it out...it only happens in the winter for me...
or if you feel like doing something you can reseal it yourself...
Old 01-20-2007, 10:29 AM
imroadk1ll's Avatar
i got the same problem i have the oem lens itsmaking my lights dim u think its the bulb thats the problem why the lens fogs up?
Old 01-20-2007, 10:27 PM
Sean DM's Avatar
Default Re: (Boost_Junkie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boost_Junkie &raquo;</TD></TR><TR><TD CLASS="quote">is it oem headlight or did you open it to blackhouse?
or if you feel like doing something you can reseal it yourself...</TD></TR></TABLE>
asking the same thing..
if its ebay then let it defog and seal it up with silicon or a sealent.
Old 01-20-2007, 11:12 PM
Miracle's Avatar
Default Re: (Sean DM)
There could either be an issue with the housing sealant, or the rubber mating spots at the bulb plug housings. And if that is the case.......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sean DM &raquo;</TD></TR><TR><TD CLASS="quote">let it defog and seal it up with silicone sealer.</TD></TR></TABLE>
Old 01-20-2007, 11:37 PM
imroadk1ll's Avatar
do i have to take out the front bumper to take out the lens?
Old 01-20-2007, 11:53 PM
Miracle's Avatar
Default Re: (drivingmylif3)
Yes... you will need to remove the bumper to get at the bolt that holds the headlight to the radiator support.
Old 01-21-2007, 12:04 AM
imroadk1ll's Avatar
Default Re: (Miracle)
thanx so wat do u think is the problem with my headlights is it becuase of my bulb or its plainly because its stock lens
Old 01-21-2007, 12:09 AM
Miracle's Avatar
Remove headlights...
Clean them out of condensation/water
Reseal them with GOOD sealer to eliminate a future problem.
Old 01-21-2007, 12:17 AM
imroadk1ll's Avatar
ok but should i just buy new headlights that are more clear?
Old 01-21-2007, 06:46 AM
Sean DM's Avatar
no.. you shouldnt have a problem after you clean it and seal it better.
mark2583
01-24-2010 04:25 PM
HeirApparent
08-31-2008 07:06 AM
Baron55
11-08-2006 11:24 PM
roundworldsobig
07-19-2006 08:33 PM
integra99blue
01-15-2002 06:39 AM
Quick Reply: Moisture In Headlight
