Manual transmission problem - Honda-Tech
Old 08-08-2006, 09:27 AM   #1
return_2020's Avatar
Default Manual transmission problem
Here is my problem. 03 civic manual. I have noise coming from transmission. this noise is like bearing noise, you can hear it while its in netural and goes away when you press the clucth. according to the below link, its an input shaft bearing problem. http://www.7thgencivic.com/for...46971
I took it to the honda dealer and they said they need to replace fork pivot and bearing and that will fix the problem. and estimated for $645 for parts and labor.
Is dealer right ? if you diagnose it properly using the link above, it seems like input shaft bearing. Please advice.
return_2020 is offline   Reply With Quote
Old 08-08-2006, 10:07 AM   #2
devani's Avatar
Default Re: Manual transmission problem (return_2020)
That's about right....the estimation is good price....where in NJ did you go to?
You said pivot and bearing...so I am assuming the correct bearing....
devani is offline   Reply With Quote
Old 08-08-2006, 05:20 PM   #3
2003hondacivic's Avatar
i am having the same thing with my 03 civic
a transmission place tolled me that it is a input shift
what do you say
2003hondacivic is offline   Reply With Quote
Old 08-10-2006, 05:02 PM   #4
B16CivicEX's Avatar
mine is exact same thing, when clutch pressed in noise goes away... have not brought it in yet, most likey input shaft bearing.... my question is, how safe is it to drive for a while like this, mine is not super loud yet.
B16CivicEX is offline   Reply With Quote
Old 08-10-2006, 05:14 PM   #5
B16CivicEX's Avatar
how much are people paying for the input shaft bearing.
Old 08-10-2006, 05:30 PM   #6
Default Re: (B16CivicEX)
i have been driving my car for about 1 year like that and it is not getting louder
i dont know if that is good or not
Old 08-10-2006, 05:33 PM   #7
does any one know if this has a recall
Old 08-10-2006, 05:42 PM   #8
Vantage's Avatar
not a recall.
Vantage is offline   Reply With Quote
Old 08-10-2006, 10:09 PM   #9
iwantspeed's Avatar
Default Re: (B18a_CRX)
make it one. talk to honda. i want a new free part.
iwantspeed is offline   Reply With Quote
Old 08-10-2006, 10:43 PM   #10
Sanji
toyomatt84's Avatar
Do you think we work for Honda or something? It's not that easy, to introduce a recall.
toyomatt84 is offline   Reply With Quote
Old 08-10-2006, 10:52 PM   #11
iwantspeed's Avatar
Default Re: (toyomatt84)
ehhh i figured someone had a hookup....
Old 08-11-2006, 11:04 AM   #12
Default Re: (iwantspeed)
now every one suggests its an input shaft bearing and i even knew that but when dealer dianosed it, they found something else. fork, pivot and release bearing. i know its not going to solve this problem. Can i take it to other dealer and have them check ito ut ? also will the other dealer know i have taken my car to the dealer before to diagnose it ? please advise. i want honda to fix it but they are showing different problem.
Old 08-11-2006, 11:48 AM   #13
Grace Under Pressure
Newborn_'s Avatar
Yeah, take it to another dealer. It wont hurt to get a second opinion. When you say it goes away when you press the clutch, it could easily point to the release bearing and fork.
The second dealer wont know if you've taken it in somewhere else first...but if they find out, so what anyway?
Newborn_ is offline   Reply With Quote
Old 08-26-2006, 06:06 AM   #14
B16CivicEX's Avatar
anyone had to change there input bearing yet
Old 09-01-2006, 06:06 PM   #15
B16CivicEX's Avatar
up
Old 09-08-2006, 01:43 PM   #16
96typeR's Avatar
had a bearing noise and it only happend when the clutch was let out, i pulled the tranny put a lot of high temp high pressure grease on the pivot fork and throw out bearing and vwalla no more noises
96typeR is offline   Reply With Quote
Old 06-01-2008, 12:16 AM   #17
202civic's Avatar
Default Re: Manual transmission problem (devani)
ok here is what your problem is. i have a 2002 civic lx and i had the same problem till last night. its most likely you rear main case bearing or in a long shot your front main case bearing. i went to Honda and the parts monkey messed up and gave me the wrong bearing. i recommend that you go buy the front and rear main case bearing and the oil seal for the front main case. and when you do make sure that you have the right part the rear main case bearing is substantially larger than the front so make sure on that. And they are both ball bearing type just so you know, the Honda dealer (Spreen Honda) said it was a needle type bearing.
202civic is offline   Reply With Quote
Old 06-01-2008, 12:32 AM   #18
Sanji
toyomatt84's Avatar
Default Re: Manual transmission problem (202civic)
Quote:
It's been almost 2 years since anyone posted in this thread. Why did you bump it up?
Whirring Noise from Manual Transmission CptHMCrunch Honda Prelude 1 07-16-2015 06:10 PM
FS: AEM UEGO wideband gauge type jwcardy For Sale 4 10-19-2004 07:36 PM
New exhaust is on! 5thgencivic Honda Civic / Del Sol (1992 - 2000) 18 01-21-2004 06:48 PM
SRP D16 8.5:1 Pistons and JE Rings For Sale. 5thgencivic Classifieds: Forced Induction 4 12-09-2003 02:52 AM
Testing waters. SRP 8.5:1 D16A6 pistons. 5thgencivic Classifieds: Forced Induction 24 12-07-2003 10:30 PM
Tags
03, 2001, 2002, 93, bearing, civic, honda, input, issues, manual, noise, number, price, problems, shaft, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
