how to change a turn signal (hazards) relay: 03 honda civic dx - Honda-Tech
Old 08-24-2011, 02:39 PM   #1
Default how to change a turn signal (hazards) relay: 03 honda civic dx
This is for anyone having trouble with their turn signals AND hazards on a 2003 Honda Civic DX. This forum helped me piece most of it together, but some info was missing that I hope this will cover for future relay sufferers.
My signals and hazards were doing all these things, in no order:
blinking a few times then stopping
not turning on
working fine
blinking steadily, then flickering, then steadily, then stopping.
Internet research told me it was an issue with my turn signal relay (which does control your hazards as well - there was some misinformation about this at AutoZone). Then I had a REALLY REALLY hard time finding that turn signal relay in order to change it.
Here is a picture for you, future reader. May you not spend 4 hours looking for it and trying to replace the wrong relay, as I did.
1. it's in your under-dash fuse box. AutoZone will lie to you and have you puzzling over the one under your hood. Don't listen to them.
2. Pop off that panel just under the steering column. So easy! Enjoy things being easy because they won't be after this.
3. Be smart right now and shake out your drivers floor mat. No. really. Also set up a chiropractor appointment if you do that kind of thing.
4. Get down on your knees on the ground. Slide the drivers seat as far back as it will go. Flip over and lay down on your back with your head in the floorboard next to the gas pedal. Great. That's the only way you can do this.
3. Look at that fuse panel. There's a screw on the lower right hand side. It's screwed on really tight. Unscrew it and take the screw out completely.
4. Pull the entire fuse panel down. At the top right, buried under a lot of cables, is that turn signal relay. It is locked in there by some very firm tabs at the top and bottom. I recommend growing a third arm to do this right, but if that isn't an option, try to just jimmy out one tab at a time. You are going to have to pull damn hard.
photos here: http://flic.kr/p/ag3hHK
and here: http://www.flickr.com/photos/misslacy/6077404821/
5. I didn't test this out, but the AutoZone $10 relay was about twice the size as the one that was a tight fit under the dash (I also read that this was an issue for an Odyssey owner who ended up wasting that $10), so I sucked it up and went to the Honda dealership and paid $20.99 for an OEM.
6. Pop the new one in. Yes, those tabs are going to get in the way again, but not as bad. Screw the fuse panel back into place with that lower right screw. Pop that panel back on.
YOU DID IT! Good job.
lkc3000 is offline   Reply With Quote
Old 05-17-2014, 09:15 AM   #2
Default Re: how to change a turn signal (hazards) relay: 03 honda civic dx
hello, I registered just to drop you a thank you. I spent awhile under my dash trying to figure how I was going to get to that relay. Everybody else made it sound like it was so easy, but my sore fingertips told me it was NOT going to be easy :-)
Thanks to you I saved quite a bit of time trying to pull out that thing.
Everything is working great now!
Sincerely...
thankyou is offline   Reply With Quote
Old 11-06-2014, 11:09 AM   #3
Thank you thank you thank you! I don't know how I didn't see that screw to drop the fuse box. It's hard enough getting it out with the box dropped, I spent an hour trying to get it out with it all the way up behind the dash lol. In business now, thanks again!!
timmy074 is offline   Reply With Quote
Old 02-08-2015, 01:29 PM   #4
Thank you for posting this. Ordered OEM from Honda, had the part replaced in 10 minutes thanks to your post! Not as flexible as I used to be, though!
PS - mine is a 2001 Civic LX manual and no changes needed for the description.
Coopgirl703 is offline   Reply With Quote
Old 04-03-2016, 03:41 PM   #5
danman281's Avatar
I just signed up to say Thank you for your post.
My 2005 Honda Civic SI (EP3) had similar issues and replacing the Relay fixed it.
Symptoms:
-Turn Signal (Blinkers) sometimes or would not turn on, left or right.
-Hazard lights sometimes or would not turn on.
-Blinking rate would vary - Sometimes it'll blink fast and sometimes it'll blink slow.
I changed out the relay using a generic (Autozone) relay. It was from Duralast and cost me $10.99 plus tax. The Duralast P/N is 20111. I believe the OEM part number is 38300-S5P-A01.
What really helped was removing that bolt to allow the entire fuse box to slide down. This made it a lot easier!
danman281 is offline   Reply With Quote
Old 04-03-2016, 10:59 PM   #6
Sanji
toyomatt84's Avatar
Just so you're aware, danman281, this forum is for the non-hatchback Civics. The EP3 chassis forum is tied in with the DC5 (RSX) forum.
toyomatt84 is offline   Reply With Quote
Old 04-23-2016, 12:51 PM   #7
Thank you so much for this thread. As the posters above me have stated, your information saved me money and hassle. Seeing how 'easy' this was in other threads had me so frustrated until I stumbled upon your input. God Bless You!
MikeUnhinged is offline   Reply With Quote
5th Gen Turn Signal Flasher Fix BigRonDawg Honda Prelude 1 10-20-2016 08:38 PM
Turn Signal Turns On Hazard Lights (civic eg) andoshan Honda Civic / Del Sol (1992 - 2000) 2 01-21-2016 01:27 AM
Turn Signal Relay location? stops Lighting 0 06-08-2015 07:24 AM
Signal Relay Location - 2013-15 RDX stops Odyssey | Ridgeline | MDX | Pilot | RDX | HR-V 1 06-07-2015 09:48 AM
turn signal indicator issue. need assistance please! zsudz922 Honda Prelude 5 05-23-2015 08:42 PM
Tags
02, 2000, 2002, 2003, accord, blinker, change, civic, ep3, fuse, honda, pictures, relay, signal, turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
