How can you tell if your wheel bearings are going out - Honda-Tech
Old 06-09-2009, 07:43 PM   #1
Jamezvtec's Avatar
Default How can you tell if your wheel bearings are going out
if i turn the wheel one way its really quite and when i am goin str8 its like a roaring sound
Jamezvtec is offline   Reply With Quote
Old 06-09-2009, 08:13 PM   #2
jdmfreak1992's Avatar
Default Re: How can you tell if your wheel barrings are going out
Hmmm could be aliment do you have any unusual tire wear. Wheel bearings do make a kind of woshhhing noise when going strait and when you turn the wheal sometimes it will go away. My guess it is a wheel bearing. Jack up your car and see if you can move the wheel side to side like this http://www.youtube.com/watch?v=5khjK0y6PIw most likely its a bad wheel bearing. It probably isn't aliment but my friend had a car that had a bad aliment and forever we thought it was a wheel bearing.
jdmfreak1992 is offline   Reply With Quote
Old 06-10-2009, 03:43 AM   #3
thisguyhere's Avatar
Default Re: How can you tell if your wheel bearings are going out
like the video.. i'm going to need to try this now lol.. i think mine are bad as well.
thisguyhere is offline   Reply With Quote
Old 06-10-2009, 10:02 AM   #4
01_civic's Avatar
how much are wheel bearing replacements?
01_civic is offline   Reply With Quote
Old 06-10-2009, 04:18 PM   #5
zxzxmikexzxz's Avatar
You may have to buy the whole hub, thats what i had to do on my gf's sable. Its easier then replacing bearings anyway.
zxzxmikexzxz is offline   Reply With Quote
Old 06-11-2009, 04:13 PM   #6
ken9's Avatar
I have this problem before but have determine which wheel's making noise? If you think that wheel's making noise then i did go change it. Sometime it could be the tires making noise. This happens
ken9 is offline   Reply With Quote
Old 06-11-2009, 04:37 PM   #7
waaBAAH's Avatar
a cupped or feathered tire could make a growling noise. normally rear tires cup on the inside of FWD vehicle. if you recently rotated then heard the noise....then this would be the case. run your fingers across the inner tread or outer tread of the tires. if you fingers vibrate when doin gthis then your tires are cupped. cupped tires are genarlly from lack of rotates. every 5k-6k they should be rotated
a wheel bearing can make a growling noise. grab the tire like in the video. or you can spin the tire in the air and hold onto your spring. the spring will send vibrations from teh wheel bearing into your hand.
an alignment will NOT make a growling noise. it might be a good idea to get an alignment if your tires are cupped...but an alignment in itself will not make the noise.
waaBAAH is offline   Reply With Quote
Old 06-11-2009, 05:43 PM   #8
Eyger's Avatar
Jack up the car and do what the video shows, just see if it feels loose or whatever. I did this to mine and its blatantly obvious. Hondapartscheap.com has the OEM bearing at like 60 bucks. I'm going to try and do some time next week.
Eyger is offline   Reply With Quote
Aluminum wheel lip repair.... smash fascism Honda / Acura 2 04-10-2005 11:50 PM
noise turning wheel green98civic Honda CRX / EF Civic (1988 - 1991) 5 12-11-2003 11:26 AM
WTT: 98 Integra SRS wheel, for JDM EG wheel (black) Mr. Thunderlips For Sale 1 05-05-2002 09:59 AM
Stock steering wheel diameter. nfn15037 Acura Integra Type-R 13 03-04-2002 06:06 PM
jdm type r steering wheel smaller than del sol wheel??? topher Tech / Misc 8 02-05-2002 05:14 PM
Tags
2001, acura, bad, bearing, bearings, brg, car, civic, decide, honda, integra, roaring, sound, wheel, whern
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
