Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Honda TSBs (Technical Service Bulletins)
Old 01-03-2008, 04:28 AM
JimmyM86's Avatar
Default Honda TSBs (Technical Service Bulletins)
These were all pulled up using my car (04 DX), but many of the TSBs relate to other trims.
I'm not sure if there is a better file server out there, but this is the first one I came to. It seems you have to deal with ads, but oh well...If you are having problems, and would like one sent to you, PM me your contact info and which ones you want and I'll email them to you.
Each file is using the following format:
TSB Name - Date Issued - TSB Number
Let me know if you have any problems with these. Hope these help!
2004 Honda Paint Codes 9-23-2003 (03-065)
AC Leak Detection 6-15-2007 (07-030)
Accessory Security System Changes Modes By Itself 7-1-2005 (05-025)
ATF Cooler Cleaner 6-18-2004 (89-022)
Audio Unit In-Warranty ExchangeOut-of-Warranty Repair 5-13-2005 (98-019)
Audio, Navigation, and RES Unit In-Warranty Exchange, and Audio and DVD Player Out-of-Warranty Repair 1-24-2006 (06-001)
Automobile Service Publications and Supplies 11-12-2005 (98-015)
Automobile Service Publications and Supplies 3-18-2005 (98-015)
Automobile Service Publications and Supplies 6-11-2004 (98-015)
Battery Test Procedure 3-19-2004 (88-023)
Battery Test Procedure 4-19-2006 (88-023)
Brake Disc Refinishing Guidelines 10-6-2006 (00-088)
Child Seat Anchor Locating Button is Missing 6-7-2005 (05-016)
Clarification of Honda Unibody Repair Policy 2-2-2007 (07-0080)
Cutting Sidewinder-Type Keys With the MATRIX H Key Cutting Machine 1-12-2005 (01-077)
Cutting Sidewinder-Type Keys With the MATRIX H Key Cutting Machine 4-19-2006 (01-077)
Deformed Windshield Molding 11-8-2003 (00-064)
Deformed Windshield Molding 8-3-2004 (00-064)
Door Lock Cylinder Binds 10-29-2004 (03-068)
Door Lock Cylinder Binds 4-20-2004 (03-068)
Drivers Seat Rocks 2-22-2005 (01-057)
DTC P1298 Is Stored in the ECM-PCM 5-6-2005 (05-006)
Immobilizer System (Type 3) 6-27-2007 (01-053)
Inaccurate Fuel Gauge Reading 3-4-2005 (05-002)
Initializing the OPDS Unit 7-16-2004 (02-052)
Lower Ball Joint Replacement 12-21-2004 (04-079)
Music Link (For iPod) General Information and Symptom Troubleshooting 2-16-2007 (07-012)
Paint Damage From Environmental Fallout 1-15-2007 (99-062)
Power Window Does Not Work or Works Intermittently 3-8-2006 (06-010)
Rattle From the A-Pillar Trim or the Dashboard Corner 5-28-2004 (04-031)
Recommended Materials 2-10-2007 (99-030)
Removal of Clear Guard Protective Film 10-28-2003 (03-080)
Removal of Clear Guard Protective Film 4-22-2005 (03-080)
Required Special Tools and Equipment 11-28-2005 (99-018)
Required Special Tools and Equipment 3-2-2007 (99-018)
Required Special Tools and Equipment 4-20-2005 (99-018)
Required Special Tools and Equipment 7-12-2005 (99-018)
Special Tool Loan Program 2-13-2006 (98-051)
Squeak at the Clutch Pedal 1-11-2005 (02-002)
Squeak at the Clutch Pedal 3-16-2004 (02-002)
SRS Indicator Comes On With SRS DTC(s) (15-1, 15-2, 15-3) 4-23-2004 (02-034)
Trunk Lid Is Difficult to Close 11-5-2004 (02-061)
Tubeless Tire Repair Information 12-15-2006 (06-082)
Updating Control Units and Modules 1-25-2005 (01-023)
Updating Control Units and Modules 6-16-2007 (01-023)
Updating Control Units and Modules 9-20-2005 (01-023)
Updating the Honda Interface Module (HIM) Model 3557-0100-00 2-17-2004 (04-009)
Vehicle Does Not Move in Drive; MIL Comes On or D Indicator Blinks With AT DTC P0730 1-7-2005 (04-036)
Vehicle Pulling or Drifting 1-12-2007 (06-068)
Vehicle Pulling or Drifting 10-3-2006 (06-068)
Vehicle Pulling or Drifting 11-18-2006 (06-068)
Warranty Extension - Vehicle Warranty Mileage 11-21-2006 (06-085)
Warranty Extension - Vehicle Warranty Mileage 5-25-2007 (06-085)
Warranty Extension OPDS Unit or OPDS Sensor Triggers SRS DTC(s) (15-1, 15-2, 15-3) 3-14-2006 (06-009)
Water Leaks Into the Trunk From a Body Seam 2-18-2005 (03-067)
civichb20
14
01-26-2010 05:18 PM
.nate
03-26-2004 10:19 AM
G-MO
05-08-2003 10:51 AM
BlueR
04-16-2002 10:08 AM
Quick Reply: Honda TSBs (Technical Service Bulletins)
