Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Oil in spark plug well
Old 07-04-2008, 03:45 AM
donaldo88's Avatar
Default Oil in spark plug well
01 Civic EX, 105K miles. Changed plugs and found about 2-3 cc's of oil in the well when I pulled coil off. Sucked some of it out with a syringe before taking plug out. There must be an O-ring or gasket under the valve cover that's supposed to prevent this. Our 96 Accord Vtek has a similar design and this never happened in twice the mileage. Is this chronic for this engine? I assume I need an entire gasket set to proceed. How tough is this? Thanks,
Don
Old 07-04-2008, 08:29 AM
em2power's Avatar
Default Re: Oil in spark plug well (donaldo88)
im not sure what to do, but for the record its "vtec" not vtek, vtac, vtech or anything else...
Old 07-04-2008, 10:40 AM
Sanji
toyomatt84's Avatar
Well, If your headgasket is shot, you're looking at $200+ for that gasket alone... not including labor (which is quite more expensive). If it's piston rings, you'll need even more money. But, I would say it'd be worth having a trusted mechanic look at before investing in anything.
Old 07-04-2008, 05:18 PM
Miracle's Avatar
Default Re: (toyomatt84)
I don't think that it would be anything MAJOR... like a headgasket or whatever...
How about the spark plug tube seals? They seal off the cams and it's oil from the spark plug wells.
My wife's car sprung a leak like this, and a new valve cover gasket and tube seals took care of the problem.
Just a thought.
Here's an illustration for purpose of knowing what I am talking about... it's #6 in the diagram:
Old 07-04-2008, 05:19 PM
Function>Fashion
Harlowe's Avatar
Check all the seals on the valve cover, before jumping to major conclusions. I bet it's just the plug socket gaskets. They are real easy to replace too.
Old 07-04-2008, 07:12 PM
gwapocivic's Avatar
Time for a new valve cover gasket, and spark plug tube seals. They can fail from time to time. No head gasket needed.
matryx
12-15-2007 01:18 PM
teletekman
03-02-2006 07:07 AM
luciffer
03-18-2005 07:43 AM
fasteddy91
04-04-2003 08:43 AM
capcon83
04-23-2002 11:21 PM
Quick Reply: Oil in spark plug well
