Where oh where is my coolant going?
Head gasket?
2004 Civic EX w/ 150k overheating while stopped at lights or stop signs.
Replaced -
radiator fan and motor
coolant temp sensor
thermostat
water pump
fan switch relay
low temp fan switch
then coolant again and again.
I have seen no leaks as I park in the same two spots (work and home) This morning i checked the coolant and again it was low. but this time when I removed the radiator cap it hissed as if it was pressurized???
Any head gasket DIY? I will not attempt but I would like to read up.
Replaced -
coolant temp sensor
thermostat
water pump
fan switch relay
low temp fan switch
Re: Where oh where is my coolant going?
Hey I had this same issue and it was the water pump piping that runs along the back under the intake manifold. You couldnt see it from the top or the bottom it was just an akward place where it rusted out. Mine my had 250k and the head gasket went cause i stopped caring about the coolant ha. So i swaped a motor with 76k in and it wasnt till the old one was out that I saw it. sorry for the novel just seems very similar to my problem.
Have you checked your spark plugs to see if you're burning coolant, if you are then one of your plugs should be cleaner then the others.
No it never seemed to leak it would just all disapear and I would have alittle along the back of my block. you could honestly just reach over the piping to see if it is rusted, mine was rusted out about an inch long and I could see where it just let it all run out.
Abe yes this has been an issue over a few months. I have looked into most of the write-ups. my fan wasnt turning on at first but after replacing relay and fan switch its working fine.
oddly, i did throw a code for high voltage for a temp sensor i think??? any ideas?
Replace the radiator cap... my car is doing the same thing, i replaced the water pump and timing belt 2 months ago. ever since i noticed the car would start to over heat, i would check the level and it would be low. add some and it would be fine for 2-3weeks, then do it again. so i replaced the thermo and cap. next time its low look to see if there is coolant in the battery tray, or on the fan. your loosing coolant as the pressure builds while you drive, the cap can't handle the pressure so it seeps out. when the motors off no pressure so no leaks. fill the coolant and leave the cap off start the car and see if the coolant bubbles rapidly if it does you have a head gasket issue.
Of course it's going to bubble if there is air trapped in the cooling system. It's not due to insufficient burping, so ...
no it's not safe to say...he said himself there's no coolant on the ground. most people either dont think to look for those signs or need a second pear of eyes. Im not saying he's an idiot, i just see people say "ya i checked" when they over looked it. the wet spots would look just like you ran through a puddle and if let sit the coolant will dry up.
again if he does have the tools to test for a head gasket the next best thing is white smoke, wet plugs, or bubbling coolant and mixed coolant/oil. yes bubbling will happen if there's air trapped but is should just bubble slowly and eventually stop. the air that is trapped could also give that pressurized should he was talking about. RAPID bubbling is do to the combustion gases and yes its not 100%, but its a good way to check.
this is just my two pennies, 10dollar cap, vs. head gasket?
It's not a wild goose hunt, looking for spilled coolant. You also instructed him to look for coolant in the most-obvious of places. You're not saying he's an idiot - you're just implying that he didn't bother looking or otherwise can't tell the difference between water which has splashed up from the roadway and coolant, colored and odorous, which has managed to leak from the system. Maybe I'm just misunderstand what you're saying.
I'd love nothing more than for the OP to return and honestly say that a new radiator cap has fixed his overheating issues. I'm skeptical, but let's wait and see.
White smoke? Indeed, a solid indicator. But it isn't happening.
Bubbling? Usually caused by a bad gasket allowing air into the system.
Mixed oil/coolant? Rarely seems to happen with these Civics. I haven't seen one person on here who's had oil and coolant mix together, even though their head gasket was bad.
Pear of eyes, hm? Okay then!
Doesn't*
Doesn't*
Anyways... most obvious for you and me, may not be for him. He asked about head gasket diy so im implying he doesn't know too much about the subject or what to look for. You implying it the head gasket no question asked.
we have a shop here in my town that declares head gasket with any coolant issues because there's moisture in the exhaust!:s i still dont understand how there in business. A buddy of mine got quoted 2300 bucks from there and he came to me for a second opinion, I change the thermo and it was fine. other time a guys car overheated only on the highway another quote and i change the cap...bam! never another problem.
in this case IF (and i will be happy to admit if im wrong) he has a blown gasket more than anything it would be smoking if hes losing coolant as often as he says. right? since you said this isn't happening.....then it has to go somewhere. so i say the cap. My question for the OP is how many miles from work- home?
also if he added coolant and missed the hole it would run onto and down the fan. it's easy to mistake that coolant for coolant leaking out later. overheating happens at the wrong time especially if your in a hurry you dont have time to wipe down the fan or any other spilled coolant.
I also assumed that if it were leaking because of a bad radiator cap that he would notice fresh coolant somewhere in the engine bay or on the ground. Since he's not, I also assumed that the exhaust isn't forcing the coolant into and out of the overflow reservoir, leading me to believe that the coolant is being vaporized but not enough to cause plumes of "white smoke." It does happen.
EDIT: Have you noticed how many times this thread has been viewed compared to the others in this particular forum? I might have to start charging admission to this show. Ha!
Last edited by It Wasn't Me; 04-21-2012 at 10:16 PM. Reason: inquiring minds want to know
My apologies..I was unaware this tread was booming. I forgot to subscride lol
The cap is new. Sry I could have save you guys time with that answer lol also no signs of leaks anywhere. I just did a 5lug swap and copliance bushings so I spent a bit of time under the car. I will check the battery tray but the fan area and enginbay has been clean although it is a very small amount disappearing every 10 days or so deff no white smoke. it does bubble a bit but i wouldnt use the term rapidly. All of the plugs look decent and identical across all four.
i would let the car idle for awhile to see if the bubbling stops, so air isn't trapped in the system. or i would buy a leak down or use a compression tester and unscrew the one way valve and charge each cylinder to see if its bubbling with the car off. Since the cap is new, i was wrong with my diagnosis.
