Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Hissing sound when clutch is pressed
Old 10-29-2013, 07:02 PM
ampr's Avatar
Default Hissing sound when clutch is pressed
i just bought a 02 civic coupe and as i was about to leave the parking lot from school i noticed that there was hissing sound when i pressed on the clutch pedal also i feel some vibrations on the pedal when i put my foot on top of it slightly pressing it, then the hissing gets a tad louder when depressed fully. anybody knows what that is?
ampr's Avatar
Default Re: Hissing sound when clutch is pressed
also a bit later when i was on the road home cel turned on help
Old 10-29-2013, 07:11 PM
Jjbaehr's Avatar
Sounds like your main shaft bearing is going bad. Does it happen in 4th gear?
Old 10-29-2013, 07:15 PM
ampr's Avatar
it happens on neutral going to 1st>2nd>3rd, havent noticed it on other gears. i would also like to assume on every other gear *preparing for the worst*
Old 10-29-2013, 08:49 PM
ampr's Avatar
i took it on a drive around the block a few minutes ago. it does make a hissing sound everytime i depressed the clutch pedal.
Old 10-30-2013, 02:33 AM
Jjbaehr's Avatar
I've seen it many times with this model civic at my dealership. The main shaft bearing is going bad. If you could provide a audio or video clip I'll be able to confirm it. Is it almost like a growling type noise?
Old 10-30-2013, 07:40 AM
ampr's Avatar
Its not a growing sound. It is most of the time consistent as to what i have observed. I will try and get a clip of it later. It can bately hear it when inget to higher gears though since theres more stress in the engine thus producing more sound. I also try to shift as fast as i can to avoid stressing the clutch too much. Ill get back as soon as i can
josephemorgan91
11-21-2015 01:53 PM
hondadnoh
22
02-11-2014 08:15 AM
Ser1N
12-04-2007 07:29 AM
'05 SubyD
11
05-18-2005 01:13 AM
echo999
02-04-2002 04:41 PM
Quick Reply: Hissing sound when clutch is pressed
