GETTING HOT WHILE IDLING - Honda-Tech
Old 08-14-2010, 11:10 AM   #1
Default GETTING HOT WHILE IDLING
I have a 2001 honda civic that continues to get hot when i am sitting and idling for more then 3 minutes or so. Then when I rev the motor or start to drive down the road the temperature will return to normal. I replaced the thermostat but it still has the same problem, although since I replaced the thermostat it seems to not get hot as fast as it used to. I am thinking maybe I got a defective thermostat or possibly the water pump is out. Just wondering if anyone else has encountered a similar problem.
Thanks
jmacc8 is offline   Reply With Quote
Old 08-14-2010, 04:15 PM   #2
Pothole987's Avatar
Default Re: GETTING HOT WHILE IDLING
Any Cels? is your fan working?
Pothole987 is offline   Reply With Quote
Old 08-14-2010, 05:30 PM   #3
water pump,fans,head gasket, temperature sensor,radiator flush or more who knows..
Hollywood_Cal is offline   Reply With Quote
Old 08-14-2010, 07:45 PM   #4
jdmfreak1992's Avatar
Did try burping your rad? Is the fan coming on, if not check the relay?
jdmfreak1992 is offline   Reply With Quote
Old 08-19-2010, 04:33 PM   #5
AutoXer's Avatar
Usually when the car gets hot when sitting, and cools off when driving, it's a fan issue.
Check if it turns on when sitting and getting hot. If not, there's your problem. I had the fuse go on mine once.
AutoXer is offline   Reply With Quote
Old 08-19-2010, 04:38 PM   #6
ballisticej1's Avatar
Check fan(s) if they're good then its a head gasket.
ballisticej1 is offline   Reply With Quote
Old 08-19-2010, 05:54 PM   #7
theineffable's Avatar
did you change your coolant recently? try burping the air out?
i would say water pump but the OEM water pump has metal fins so i don't think there's a problem w/ broken fins...
theineffable is offline   Reply With Quote
Old 08-19-2010, 06:21 PM   #8
CRX Si69's Avatar
your thermostat isnt opening.
CRX Si69 is offline   Reply With Quote
Old 08-20-2010, 12:52 PM   #9
i've got an '02 d17a1, same problem, just needed to top up coolant cause i've got a leaky head gasket. i'm getting oil in my coolant res but have'nt seen any coolant in my oil
2002-dxsedan is offline   Reply With Quote
91 accord fan issues axydorfus Honda Accord (1990 - 2002) 4 07-14-2016 02:01 PM
lost...plz help!!! - Question about thermostat and overheating Ej2guy28 Honda Civic / Del Sol (1992 - 2000) 7 11-26-2012 09:29 AM
94 Civic water circulation problem russ61nc Engine Management and Tuning 4 01-11-2010 12:58 PM
weird idle problemo that_boy_sammy Honda Civic / Del Sol (1992 - 2000) 15 11-23-2009 01:15 PM
car overheated... changed stat... now everyhthing is just hot!!! 94c1v1cex Honda Civic / Del Sol (1992 - 2000) 11 08-07-2007 07:56 PM
Tags
06, 2002, 2005, accord, burping, car, caused, civic, cools, driving, fan, honda, hot, idling, integra, motorcycle, radiator, runs, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
