Es1 k20a3 swap
Es1 k20a3 swap
Hi guys I have a 7th generation 2001 Right Hand Drive automatic honda civic with a d15y6 engine in it (I'm from the caribbean) and I'm looking at swapping this engine with a k20a3 engine. I want to leave the car as automatic due to the fact I was given the engine with an auto transmission and ecu. I read the diy you guys have posted but it caters to the em1 with the D17 therefore I still have couple questions .
1.Can I base to swop on this diy.
2. If I have the engine and the auto transmission to go it , along with the ecu, is it just a drop in with the hasport mounts and wire harness conversion?
3. Do you have to have to have the subframe.
Or if there is a guide u could direct me to for this model specifically cause I wasn't able to find one.
I know u guys would say make it manual and it wouldn't make sense but I'm getting engine, transmission and ecu free so not looking to spend extra for manual transmission.
Thanks in advance
Thanks in advance
Sanji
Re: Es1 k20a3 swap
1. I think you're referring to the DIY in the FAQ's, and if you can use it for your swap. For a lot of the swap, you could use the DIY in the FAQ's... however, a lot will differ when it comes to utilizing the automatic transmission and ECU.
2. Nope. You'll have to custom fabricate a transmission side mount, customize your dash harness to suit the automatic transmission (I do not know of any diagrams out there that could help you with this). Also, you won't be able to run K-Pro... so you'll be forced to run the stock tune on the automatic ECU, unless you do some research and try to run a piggyback (which will take a ton of research and work).
3. Yes. The front and rear engine mounts, and overall shape is different.
Finally, there aren't any guides out there for an automatic swap due to its overwhelming lack of support. You're going to be on your own for this one.
Re: Es1 k20a3 swap
So seeing the reason i was looking at changing my engine was because i am having a problem with mine maybe you could help
1. when i stop at stop lights 5- 8 seconds after the car idles down to 0 or sometimes cut out
2. the car looses power on casual driving
when i drive the car hard it revs well and changes gear well
i cleaned the IACV
all other fluids were changed
spark plugs were changed as well
i also had a diagnostic test done.
any other advice on how to correct the problem
i cleaned the IACV
Re: Es1 k20a3 swap
coil packs no alternator
i did a computer reset the car started driving ok then started feeling sluggy again, how ever it isnt idling down past 0 and it isnt cutting out either
jrobins
06-25-2011 11:53 AM
Quintos
02-15-2009 07:25 PM
baulum
08-30-2007 01:55 AM
prkoqui
07-24-2004 08:28 PM
Smith Wise
30
04-11-2003 05:48 AM
