DRL, low-beam and high-bean (headlight) issue - Honda-Tech
Old 07-05-2011, 02:16 PM   #1
Default DRL, low-beam and high-bean (headlight) issue
Car: 2003 EM2 Sedan
Headlight: 9003
Problem:
During DRL, only the driver's side headlight is on. Passenger side headlight is off. There is buzzing sound in the cabin, maybe coming from the glove box area.
During low beam, both low-beam headlights are on.
During high beam, only the driver's side high-beam headlight is on. Passenger side high-beam is off.
I already tried swapping the fuses (in the hood and under the steeling wheel) and headlights and the problem is still there. I think it has something to do with the headlight on the passenger side.
Did anyone get this before? How can I fix it? Thanks
sealocean is offline   Reply With Quote
Old 07-05-2011, 08:24 PM   #2
Default Re: DRL, low-beam and high-bean (headlight) issue
Damn...I have the same problem...i was thinking of just pulling the DRL fuses.
cardemon is offline   Reply With Quote
Old 07-05-2011, 08:43 PM   #3
Quote:
Hey I know what to do now. The sound is coming from behind the glove box. So I opened it and try to see where te sound is coming from and I think I found the problem.
After you remove the glove box, look all the way to your left. You will see two relays ("cube" like object), one black and one gray. The one making the sound is the gray one. You can pull it out (pull it vertically, to the sky). It's just like a plug.
The relay is MITSUBA JAPAN RC-5102 12v 1T 2XG.
So RC-5102 relay is the item to replace.
Now if you know where I can get it online (ship to Canada) or how much is it from dealer, let me know.
Old 07-06-2011, 10:26 PM   #4
It Wasn't Me's Avatar
You could try repairing the DRL module yourself, if that fails, buy a replacement.
From the FAQ's..
Quote:
Repairing the DRL Module: Link
It Wasn't Me is offline   Reply With Quote
Old 07-11-2011, 02:07 PM   #5
Awesome information!!!
It was just afew days ago I just got frustrated and just pulled the interior DRL fuse itself from my 2001 Civic. Cured the problem for my needs; no sound, no flickering DRL dash light.
I couldn't really care if my DRL's are on or not in a 10yr old car. At early dawn, dusk and at night is when I will actually need to turn on my main lights physically anyway.
Old 07-16-2011, 09:27 AM   #6
...Hold on...my idea of pulling the fuse may not be a good idea...I THINK I TOOK OUT MY FUEL GAUGE...DAMMIT!
I may just do the soldering thing of that unit..
Old 07-16-2011, 03:47 PM   #7
had the same problem and the fix was one of the wires that's coming from the connector that connect to the combination switch (headlight switch) was at the wrong pin. you got to get a schematic and match it to your wiring
shantech is offline   Reply With Quote
Old 11-03-2011, 07:44 AM   #8
GriFFIthS's Avatar
I started to get this buzzing over the last few days, and my high beam passendger side light doesnt come on anymore, I pulled the module out today and had a look, 10 solder joints all cracked, it amazes me that such a common problem doesnt have a recall.
Anyway ill be attempting to redo those joints tonight.
GriFFIthS is offline   Reply With Quote
Old 11-03-2011, 08:04 AM   #9
Sleepy_Red_hatch's Avatar
drl module, just fix it or pay me 40$ + shipping to send you a repaired unit, if you're in the ottawa area i can fix yours for you.
Sleepy_Red_hatch is offline   Reply With Quote
Old 03-21-2012, 07:33 PM   #10
Quote:
I have the same problem and live in the Ottawa area. Let me know when would a good time for you take a look.
Antimatter7 is offline   Reply With Quote
2003 Acura 3.2TL DRL Module djakal47 Acura TL, RL & ZDX 0 04-05-2011 11:43 AM
USDM Headlights and DRL running lights... GranadaTeg Acura Integra 5 09-01-2007 11:58 AM
is this normal for headlights? EK k kay Honda Civic (2006 - 2015) 28 08-08-2007 09:45 PM
RSX Daytime Running Lights ? LakesDC5 Acura RSX DC5 & Honda Civic EP3 4 10-26-2006 01:58 PM
DRL module?? raceboy71 Honda Accord (1990 - 2002) 0 12-06-2005 07:35 PM
Tags
2001, 2003, beam, civic, drl, element, fuses, headlight, headlights, high, honda, intermittent, light, lights, low, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
