Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Drivers door lock will not unlock or lock from inside.
Old 01-25-2013, 07:24 AM
MIBPreacher's Avatar
Icon2 Drivers door lock will not unlock or lock from inside.
2002 Honda Civic EX
Has power door locks and remote transmitter.
Remote transmitter locks and unlocks the car fine.
Key locks and unlocks the car fine.
The inside door panel switch will not lock or unlock the door (it has once,thats it)
The manual lock slide switch only slides halfway down, never actually locking the door?
If anyone has seen this issue before please let me know.
Thanks,
Rick.
Old 01-25-2013, 09:11 AM
K24_Y61P's Avatar
Default Re: Drivers door lock will not unlock or lock from inside.
Silly question but I've seen it before. Do you have the door open when you are trying to use the inside switch and push it down? If so its a anti lock out feature.
Old 01-28-2013, 09:36 AM
No this is while I'm inside the car while the door shut
Old 01-28-2013, 02:01 PM
clutch05ex's Avatar
Sounds electrical to me then. Could be a bad switch or connector.
Old 02-03-2013, 04:38 PM
ThomasMillerEM2's Avatar
if i were you i would take off the door panel and make sure everything is correct. could be something as simple as the connector to your power locks not being plugged all the way in.
pwyley
Acura TSX
04-02-2018 02:32 PM
mutiny93
06-26-2011 11:43 AM
aquito
07-15-2009 02:36 PM
danb18c
01-20-2008 05:49 AM
Intercooler
11-18-2004 08:43 PM
Quick Reply: Drivers door lock will not unlock or lock from inside.
