Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
DIY: EDM Rear Fog Install
Old 10-23-2008, 08:08 PM
SHG_James's Avatar
Default DIY: EDM Rear Fog Install (updated 10/24/08)
Items Needed:
-EDM Fog w/ Garnish & Bracket (eBay)
--Coupes, use one off a EK9 or 4thgen Prelude (i used one off the 4thgen prelude)
--Sedans, use one off a DC2 since they have an angle (check jdmland.com for pics)
-07-08 Honda Fit Combination Switch (35255-S5K-F12)
-30A Bosch Relay (eBay, get one with the pigtail)
-30ft of 16G Wire (20ft going to the fog and 10 going to relay, switch, grounds, etc)
1. Disconnect the negative terminal on the battery
2. Make a template using the lip of the garnish. This will be used to cut the hole. (i used masking tape & a sharpie)
3. For the coupes, place the template a bit higher than this. If you go any lower it will interfere with the crash beam.
For the 04-05 sedans, place the template here. not to sure about the 01-03 sedans yet.
(thanks for the pic 03civicdopejmd from honda-tech)
4. Using a dremel w/ a cut-off wheel, cut inside the line and test fit the garnish. If trimming has to be made, do it in small increments with a sanding bit.
5. Remove the garnish behind the steering wheel. There are 3 screws on the bottom.
6. Remove the old combination switch. There are 2 screws. Once that is removed use a small flathead on the little notch to expand the switch housing so the switch can be pulled out.
7. On the connector, add 2 pins to the locations in red. (you can get pins from another honda at your local junkyard)
8. Slide in the new switch & re-attach the 2 screws and the connector.
9. Remove the access panel to the fusebox and the coinholder.
10. Find a place to mount the relay. I mounted mine behind the coinholder.
11. Here’s a simple wiring diagram to show you where everything goes.
12. I got the 12v where my front fogs gets its 12v.
13. I routed pole 30 from the relay thru the driver's side door sill & rear panel.
14. At the foglight, i used quick disconnects in the event i have to remove my rear bumper
15. Finished product.
Modified by jamescardenas07 at 1:18 PM 10/24/2008
Old 10-23-2008, 08:31 PM
Function>Fashion
Harlowe's Avatar
Good writeup man!
Old 10-23-2008, 08:49 PM
LatinEM2's Avatar
Nice nice
Old 10-23-2008, 08:51 PM
over_'s Avatar
yes! very nice, im not sure i understand tho, what are the 2 pins for? where do they go to?
Old 10-23-2008, 10:16 PM
00falcon's Avatar
Default Re: DIY: EDM Rear Fog Install (jamescardenas07)
very nice. i thought you just hooked it up to your fog switch or another oem fog switch.
props for this! i'm guessing the reminder tone goes off if you accidentally leave it on?
Old 10-24-2008, 12:57 AM
SHG_James's Avatar
Default Re: DIY: EDM Rear Fog Install (00falcon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OVNI_CIVIC &raquo;</TD></TR><TR><TD CLASS="quote">yes! very nice, im not sure i understand tho, what are the 2 pins for? where do they go to?</TD></TR></TABLE>
they go here (see the red dots in the connector)
one of the pins go to the relay and the other goes to a 12v source. doesn't matter which one. (check wiring diagram)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00falcon &raquo;</TD></TR><TR><TD CLASS="quote">very nice. i thought you just hooked it up to your fog switch or another oem fog switch.
props for this! i'm guessing the reminder tone goes off if you accidentally leave it on?</TD></TR></TABLE>
i did wire it to a oem fog switch
Old 10-24-2008, 05:34 AM
homelessEm2's Avatar
NICE! clean and simple. glad to see more peeps gettin into the DIY and bein creative...props to you sir
Old 10-24-2008, 06:10 AM
EMjoy81's Avatar
Default Re: DIY: EDM Rear Fog Install (homelessEm2)
nice DIY!
A painted frame from the rear fog looks much better by this color :-)
with a black car it doesn`t matter that the frame is black.
so go and make it
Old 10-24-2008, 12:21 PM
<StevieG>'s Avatar
i think you may have it in the wrong spot for the 04-05 bumpers, unless there different on coupes but this is how the 04-05's should look, which is the way imma do it sorry to blow the bubble
Old 10-24-2008, 01:57 PM
SHG_James's Avatar
Default Re: (03civicdopejmd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EMjoy81 &raquo;</TD></TR><TR><TD CLASS="quote">nice DIY!
with a black car it doesn't matter that the frame is black.
so go and make it </TD></TR></TABLE>
very nice. i have a question for you. can you turn on your rear fog independently or does the headlights have to be on?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03civicdopejmd &raquo;</TD></TR><TR><TD CLASS="quote">i think you may have it in the wrong spot for the 04-05 bumpers, unless there different on coupes but this is how the 04-05's should look, which is the way imma do it sorry to blow the bubble
the coupe is different. dark_maul has a 04 and his is in the same location as mine. btw, is the 01-03 sedan rear fog in the same location as the 04-05?
Old 10-24-2008, 02:11 PM
SHG_James's Avatar
Default Re: (jamescardenas07)
BUMP. added 04-05 sedan info
Old 10-25-2008, 04:44 AM
EMjoy81's Avatar
the foglight only lights up, when the headlights are switched on
and additional a controllamp lights up beside the other controllamps,
like the controllamp by switching on the fullbeam of the frontlights
but the front fogs you can switch on seperately from the rear fog light.
Old 10-25-2008, 10:12 AM
SHG_James's Avatar
Default Re: (EMjoy81)
ah yea. i seen the rear fog indicator on a edm cluster someone was selling on 7thgen. does the switch i have look like yours?
Old 10-26-2008, 02:36 AM
EMjoy81's Avatar
yes, it looks identical
Old 10-26-2008, 02:53 AM
SHG_James's Avatar
mind taking pics? along with the rest of your interior?
Old 11-07-2008, 04:44 AM
EMjoy81's Avatar
uuups, sorry, i didn`t saw your answer
the next days i make a few pics of the oem interiour for you
Old 11-07-2008, 07:45 AM
SHG_James's Avatar
Default Re: DIY: EDM Rear Fog Install (EMjoy81)
thanks
Old 03-07-2009, 07:21 AM
dopejdmes1's Avatar
this is where i put mine on an 01-03 sedan
Old 03-07-2009, 06:41 PM
SuckMyDOHC's Avatar
Rear foglights go on the driver side, regardless of LHD or RHD.
Old 03-10-2009, 10:09 AM
03EXHondaOKC's Avatar
Where can I buy a kit and how much do run for?
Old 03-11-2009, 12:20 PM
Got my answer, Thanks
Old 03-13-2009, 08:40 PM
trang_man's Avatar
Very nice.
Old 03-13-2009, 10:28 PM
tunerkid7's Avatar
got mine on the way woot!!
Old 04-13-2009, 10:54 AM
New User
ApexRR's Avatar
nice, what about to install the rear fog on both sides?
what do you think, will it look nice or just too much if there are 2 in the rear spoiler?
Old 04-13-2009, 11:10 AM
Plead da Fif
It Wasn't Me's Avatar
You could install two rear fog lights, but there's only supposed to be one.
Two would look stupid. (IMO, of course.)
Quick Reply: DIY: EDM Rear Fog Install
