Dim headlight problem.
i have a prob with my driver side headlight being dim cant find the ground wire to clean it i have an 02 civic with out fog light and trying to figure out why the head lights dont work if i unplug the pasanger bulb but they do if i unplug the driver just some thing i noticed just wondering if that is a simtom of a bigger prob in my car and if what is causing that is why my driver head light is dim even with a brand new bulb
Re: eletrical
I would check your fuses first. Also might wanna make sure that the plugs for the bulbs aren't bent or sucked out.
Re: Dim headlight problem.
i know you said that you cant find the grounds but id start there or start doing voltage drop and ohm test on the lighting system. sounds like a bad wire or ground on that side of the ciruit.
That circuit grounds through the combo switch to G401, which is under the gauge assembly. You need to look for bad connections, including that ground, then do a combo switch test.
Jacen
03-22-2006 10:51 PM
