vss
vss
anybody know where i can a wiring diagram for the vss. when i pulled the trans i forgot to disconnect it ripped the wires out now it doesnt work, i cant know how it is suppose to be wired but i need to know voltages so i can tell if i broke the sensor.
Re: vss
Have you reset the ECM/PCM? -With the car OFF, pull fuse #6 in the under-hood fusebox for at least 10 seconds.
If you've already done that and the speedometer is working (or working part of the time) 1 of the connections is bad.
Jesus Chacon
02-05-2018 11:43 AM
silentblackhat
12-25-2005 03:44 PM
