Crankshaft Position Sensor Location?
Hey guys, do you know where the crankshaft position sensor is located on the 7G LX? I received a P0336 CEL code. TIA.
Re: Crankshaft Position Sensor Location? (Session101)
It is located under the lower timing cover. You will need to jack the front drivers-side up, remove the wheel. You should see a black plastic cover behind the harmonic balancer pulley. This cover has three bolts that must be removed to expose the crank sensor. I believe that you will also need to remove the harmonic balancer, and drive belts to get to the sensor bolt.
hugens26
09-19-2010 03:33 PM
RockstarJR
06-02-2004 08:43 AM
