Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Compression Loss After HG Replacement
Old 07-07-2015, 10:08 AM
bmccue's Avatar
Default Compression Loss After HG Replacement
2001 Honda Civic - LX - Standard Transmission - 302,000 miles. I replaced the head gasket at 300,000. After reassembly, engine idled roughly and started throwing a P0300 - P0303. Did a compression test and cylinder 3 was low at about 30 PSI. Wet compression test jacked it to about 50 psi. All other cylinders were within range (ruled out bad HG). During HG replacement, I sent the head out to be machined and they removed and then reassembled cam assembly. Underway I don't detect any issues with performance other than the CEL goes on after a while after a reset. I checked and adjusted valve lash and issue did not go away.
Does it seem like a ring issue to you guys?
Is it even worth fixing given this car's age/mileage (and a little rust)?
What would it be worth selling it for?
Thanks
Brian
Old 07-07-2015, 01:11 PM
Master Detailer
98civdx's Avatar
Default Re: Compression Loss After HG Replacement
Rings. Either needs a rebuild, or replace the engine.
Assuming you can do the work yourself, you could probably put a JDM long block in it for around ~$1000
No one in their right mind will pay much for the car as it sits.
rxbahamut
10-17-2011 06:33 PM
CNSK
04-10-2005 08:54 AM
Unlimitationz
02-22-2005 03:47 PM
foesicks
01-08-2003 03:16 PM
thao4life
10-08-2002 03:46 PM
Quick Reply: Compression Loss After HG Replacement
