Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2003 Honda Civic Computer Chip Help!
Old 07-19-2011, 10:50 AM
DannyKBC's Avatar
Default 2003 Honda Civic Computer Chip Help!
Hey everybody,
The computer chip in my car recently stopped working and the mechanic says I need to replace it. The ID on the chip is 37820PLML57 but I've called many junkyards and nobody has this chip. One did say they have the 37820PLML54 and that it will work without problem. I'm not sure if they're telling the truth, I hope somebody can help me with this. Thank you!
Car Info: 2003 Honda Civic 1.7, Base Model
Best regards,
Danny
Old 07-19-2011, 11:04 AM
Plead da Fif
It Wasn't Me's Avatar
Default Re: 2003 Honda Civic Computer Chip Help!
That would be your ECM/PCM, also known as the ECU.
It would be best to match the part numbers when buying a replacement. There are a number of them available on eBay.
http://motors.shop.ebay.com/i.html?_from=R40&_trksid=m570.l2736&_nkw=37820-PLM-L57
Old 07-19-2011, 11:26 AM
DannyKBC's Avatar
Oh, I see, thank you very much.
Old 07-19-2011, 11:45 AM
Plead da Fif
I forgot to mention it, but you might also want to check http://car-part.com/ to see if there are others available in your immediate area.
Old 07-19-2011, 12:22 PM
DannyKBC's Avatar
Will do, thanks again!
Old 07-19-2011, 12:27 PM
Plead da Fif
Not a problem. Just so you know, when you replace the ECU, your keys/immobilizer will no longer match it. A dealership will have to remedy that. (unless you get the key, ignition switch, and ECU all from the same car.)
YNG
08-29-2008 05:15 PM
THC07
02-02-2006 06:52 PM
Interlinker
05-25-2005 06:59 PM
GRIMREAPER
03-09-2003 01:55 PM
Quick Reply: 2003 Honda Civic Computer Chip Help!
