Civic 2005 D17A1 turbo - Honda-Tech
Old 07-11-2009, 09:21 AM   #1
Default Civic 2005 D17A1 turbo
Hi, I'm from Panama City, Panama, I have a Civic 2005 D17A1 non vtec, I installed a T3/T4 Turbo, i have it already at 7psi, but I want to know what is the maximum boost that the engine cant takes without open the head or changes on the stock materials.
Been considerated that this is my daily drive car.
I have a Profec B II boost controller so I can stage 2 settings of boost, LB -HB
The only that I changed are the injectors of 440cc, a B16A2 Intake Manifold, Clutch Stage 3, and a SAFC II to control the AirFlow
Gian"vtec" is offline   Reply With Quote
Old 07-11-2009, 10:17 AM   #2
Curiouz_G's Avatar
Default Re: Civic 2005 D17A1 turbo
what trim turbo is the T3/T4 hybrid?
How much duty cycle are your injectors running at?
What A/F ratio are you at currently?
The biggest limiting factor might not be the turbo, but your injectors. Not to mention if youre on a stock cam, you WONT be making TOO much more power above 7-10lbs.
Curiouz_G is online now   Reply With Quote
Old 07-11-2009, 10:42 AM   #3
Thats what i want to know...ok 7 to 10lbs.
Thanks a lot bro.
Old 07-11-2009, 10:50 PM   #4
i decided to post here instead of a new thread. im just curious cuz i want to turbo my civic but still have it as a dd. how much boost can i run stock with out changing internals. looking to spend under a 1000$. i just want to add some pull to my em2. 01 ex.
01em2slvr is offline   Reply With Quote
Old 07-11-2009, 11:35 PM   #5
Ben850's Avatar
Quote:
6-7
Ben850 is offline   Reply With Quote
Old 07-12-2009, 10:29 AM   #6
Sanji
toyomatt84's Avatar
This thread is for you: http://www.honda-tech.com/zerothread?id=1897200
toyomatt84 is offline   Reply With Quote
New member. Civic 08 Si FA5 MM507 Introduce Yourself 1 02-02-2016 12:49 AM
EK- turbo dreams From Panama!!! chuwi_pty Appearance Build Threads 18 07-15-2013 10:20 AM
Integra DB7 from Panama Panama_DB7 Introduce Yourself 0 05-05-2013 07:18 PM
honda integra tire pressure panama_b18c1 Acura Integra 6 04-30-2007 07:55 PM
dyno tuning... is it worth it? read pls. PanamaVTI All Motor / Naturally Aspirated 10 08-04-2004 08:53 PM
Tags
05, 2005, 7psi, boost, boosted, build, cam, civic, d17a1, gian, intake, manifold, safc2, turbo, vtec
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
