Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Car making whistling noise while on has pedal
Old 11-24-2008, 11:26 AM
HondaScott's Avatar
Default Car making whistling noise while on has pedal
Hello,
I just noticed today when I put my foot on the gas I hear a whistling type noise coming from the car. However, when I put my foot on the break the noise stops. What can it be? Its an 2002 Honda Civic with about 250k on it
Thanks
Old 11-24-2008, 11:33 AM
texasnick's Avatar
where is the whining coming from?
Old 11-24-2008, 11:40 AM
HondaScott's Avatar
I hear it from inside - could be from outside the car not sure - I left the car on in park and there was no noise just only when its on the gas - I also hear a clunking noise as well
Old 11-24-2008, 11:43 AM
daddy's Avatar
do you have an aftermarket intake?
Old 11-24-2008, 11:46 AM
texasnick's Avatar
if it's coming through the speakers, it's a grounding issue....other than that, the only advice I can give without hearing it is check your drive belt or maybe you have a super stealth turbo you just don't know about yet...lol jk.
Old 11-24-2008, 11:53 AM
HondaScott's Avatar
I dont have any super turbo things lol - and I turned the radio off and the sound was still there
Old 11-24-2008, 12:15 PM
daddy's Avatar
if you have an aftermarket intake it can make a whistling sound
Old 11-24-2008, 02:44 PM
unevolved's Avatar
I'm with Dan, sounds symptomatic of an aftermarket intake, unless you give us more information to go off of.
Old 11-24-2008, 05:03 PM
ejLday's Avatar
I had a similar situation which was caused by an exhaust flange leak. ONly when stepping on the gas too...
Old 11-24-2008, 06:57 PM
HondaScott's Avatar
Did you get it fixed and did it solve the problem? What exactly was fixed and how much did it cost?
Old 11-25-2008, 11:09 AM
texasnick's Avatar
It would be best if you could isolate where this whining noise is coming from...I mean, there's a lot of things that could make a whining noise. It would suck to spend money fixing something that someone on here recommends and have it not be the issue at all.
Old 11-26-2008, 01:42 PM
HondaScott's Avatar
Back from Honda repair done. Was the front breaks making the noise. Had them replace apparently it was almost metal to metal. HMM
Old 11-27-2008, 09:51 AM
Lewy. Dee Ayy's Avatar
my brakez be whistlin yo..twooot twooooot
Old 11-27-2008, 10:29 PM
ISHerz's Avatar
Icon6 reply:
have you had the alternator replaced? also check your a/c belt tensioner. if you want you could have meineke peek under the hood at your belts to see if they're prematurely warped. if you haven't replaced the alternator then the bearing might be the cause of the noise.
Old 11-28-2008, 06:01 AM
texasnick's Avatar
Glad to hear you got it fixed....worn pads ftl
Old 11-28-2008, 10:55 AM
ejLday's Avatar
front brakes? would have never guessed. glad you're fixed
gators113
Transmission & Drivetrain
06-24-2019 02:51 PM
jr408
03-19-2008 09:18 AM
crx1racing
05-25-2005 05:43 PM
JDMchuckles
03-06-2003 08:02 PM
Quick Reply: Car making whistling noise while on has pedal
