Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Better performance out of 05 civic LX
Old 05-25-2012, 08:54 AM
rossijay's Avatar
Default Better performance out of 05 civic LX
Need some help ... Trying to get some more performance (without doing a swap) out of it .... looking for some suggestion.... (Ready got stage 2 clutch w/ 7.8 Ibs flywheel, AEM short ram intake, and aftermarket headers installed)
rossijay is offline
Old 05-25-2012, 09:25 AM
j13
j13's Avatar
Default Re: Better performance out of 05 civic LX
You'll have to put in a better engine.
j13 is offline
Old 05-25-2012, 09:29 AM
Plead da Fif
It Wasn't Me's Avatar
► FAQ's and Guidelines - READ BEFORE POSTING!
Q: What can I do to make my engine perform better?
- A: Unfortunately, the D17 does not respond well to standard bolt-ons or natural aspiration build-ups. Even with higher compression pistons, a high-performance cam, custom intake manifold and throttle body, cold air intake, aftermarket header and exhaust, and head work, you may only see 20 to 30 whp (which really isn't worth the thousands you would invest in the project). Your three "best" options are a Nitrous kit (only up to 60hp shot on stock internals), a turbo-setup, or swapping for a K-series engine.
One thing you can do for a noticeable increase of WHP at an affordable price is to install a Crower Stage 1 cam. Match this with an exhaust system and an intake and you can see an increase of as much as 20 WHP. You do not need to run an aftermarket management system. The Crower Stage 1 cam will work with your stock ECU.
See post #9 for a dyno graph: https://honda-tech.com/forums/honda-civic-2001-2005-78/stage-1-cams-2844103/
It Wasn't Me is offline
joshii_honda
01-26-2015 09:39 AM
joshhulebak
25
06-10-2014 08:42 AM
d3v
05-18-2013 12:30 PM
EM2Insta
29
11-11-2012 07:58 AM
machidambw
44
10-01-2010 05:27 AM
Quick Reply: Better performance out of 05 civic LX
