Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Fuel Injectors
Old 04-07-2010, 07:36 AM
jackblack's Avatar
Default Fuel Injectors
Is there a difference in the d17a1 injectors and the d17a2 injectors. I did a vtec swap on my 01 civic and did the complete swap with the ex ecu and ex wiring harness and so forth. I finally got everything working the way it's suppose to yesterday and when i was leaving the shop I noticed my injectors were ticking extremely louder than normal. I know its not the valves ticking because I had just finished adjusting all of them so i'm just trying to figure out if the A1 and A2 injectors are different cc's which would cause my A1 injectors to work a lot harder now and probably cause them to be louder.
Any ideas?
Old 04-08-2010, 05:43 AM
baron340's Avatar
Default Re: Fuel Injectors
No.. they are the same. It is more than likely just the valve train. Even with the valves all properly adjusted, the vtec valve train is just noisier than the non-vtec.
boostedteg4dr
05-05-2009 02:57 PM
1clean_siRef9
04-17-2008 08:36 AM
rasinhell
06-16-2005 05:32 PM
Bintegra
14
07-29-2004 08:11 PM
LSturboHB
01-03-2002 07:28 PM
Quick Reply: Fuel Injectors
