Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
changed cam plug now car is missing?!?!?! please help
Old 07-29-2009, 03:02 PM
redb16coupe's Avatar
Default changed cam plug now car is missing?!?!?! please help
ok i changed the cam plug on my 01 ex, now i have a miss on the cylinder closest to the timing belt, changed the coil packs around to see if it was that but still does it, have a check engine light on. is there any way we can check the codes with out a scanner? im really stumped this car is my daily and im screwd... some one please help
Old 07-29-2009, 06:01 PM
Default Re: changed cam plug now car is missing?!?!?! please help
bump
Old 07-29-2009, 06:05 PM
HONDAPARTSMANMIKE's Avatar
did u lossen the cam cap??if so did u adjust the afterward??
Old 07-29-2009, 06:13 PM
yes i did loosen the caps, no i didnt adjust?>>
Old 07-29-2009, 07:18 PM
did you loosen all of them??did you remove the rocker arms at all??
Old 07-29-2009, 07:59 PM
SGolub's Avatar
Very misleading thread title.
Old 07-29-2009, 08:31 PM
90sedan's Avatar
Check and adjust the valves to factory specs and then report back.
Old 07-29-2009, 08:37 PM
jdmfreak1992's Avatar
Timing correct. Make sure the belt didn't skip any teeth
Old 07-29-2009, 09:53 PM
Plead da Fif
It Wasn't Me's Avatar
If the belt skipped a tooth, the car would not run.
Old 07-30-2009, 06:54 PM
you where totally right. i had 110 compression on #1 and 135 on the rest figured that when i loosened everything i had to re-adjust the valve lash, now i have 150 across the board.
thanks
Oney
Old 07-30-2009, 10:36 PM
thats good to hear!! is the car running good now??
Old 07-31-2009, 06:52 AM
Better than before, car is running alot smoother and has so much more power i think the lash was really off before and i just made it worse.
Devon M
09-30-2014 04:30 PM
giovannie23
10-10-2013 02:22 AM
skata89
12-19-2006 09:03 AM
cooteg6
05-19-2006 06:21 PM
EK4 hatchback
05-31-2004 08:45 PM
Quick Reply: changed cam plug now car is missing?!?!?! please help
