the ac on my honda civic 2002 will not work - Honda-Tech
Old 05-28-2012, 03:40 PM   #1
Default the ac on my honda civic 2002 will not work
the ac on my honda civic lx 2002 works for a small period of time in the morning i turn on my car the ac willwork for a good 20 min the compresor shuts down and the rpm on my car goes up if it is the middle of the day and it id over 70 the ac will not come on what can be causing this problem is it the compresor on the clutch i know its not the relays i just replaced them and had no improvement
JuanRocio is offline   Reply With Quote
Old 05-31-2012, 01:17 PM   #2
dpetro1's Avatar
Default Re: the ac on my honda civic 2002 will not work
have you checked the refrigerant levels? the compressor will turn off if the pressure is too low
dpetro1 is offline   Reply With Quote
Old 05-31-2012, 05:12 PM   #3
heat equals pressure pressure equals a/c not working check your condenser fan and make sure it's working check your freon levels to make sure your a/c compressor didn't purge freon out and if it did purge you have to replace the valve
02sia2 is offline   Reply With Quote
Old 05-31-2012, 06:50 PM   #4
eviee1973's Avatar
Likely the thermal protector doing its job, something causing it to activate due to getting too hot.
eviee1973 is offline   Reply With Quote
Old 05-31-2012, 08:59 PM   #5
j13
Quote:
Agreed^ there is a switch that shuts down the a/c. You gave a leak somewhere in the system. Go to an a/c specialist and they can track down the leak, vac the system and refill
j13 is offline   Reply With Quote
Fs rear disc setup and other honda stuff MILFHUNTERDA Mid-West (Sales) 3 03-27-2009 10:09 PM
99-00 Civic SI A/C System & HIDs Lsvtecy0 For Sale 13 09-14-2006 04:51 PM
can i use my d-series a/c comp. with a b-series swap? rextec Honda Civic / Del Sol (1992 - 2000) 5 03-09-2006 02:16 PM
wtb: EG AC compresor vtecvoodoo For Sale 1 09-15-2005 08:30 AM
Location of AC clutch relay NcNghtStkr Honda Accord (1990 - 2002) 3 08-13-2002 09:37 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
