Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
HELP PLEASE: Intermittent flickering lights- video inside
Old 03-20-2012, 05:31 PM
bk111's Avatar
Default HELP PLEASE: Intermittent flickering lights- video inside
http://www.youtube.com/watch?v=vkvkMDLkX1A
Battery was replaced by previous owners in 2009. Stock alternator with 98K miles on it. The grounds look fine and tight.
Everything works fine at idle. At higher rpms is when this problem occurs. Does not happen all the time but pretty intermittent.
What do you guys think? Where should I start? The multimeter is not sensitive enough to pick this up.
If this is the alternator what is the best source to pick up a good one?
Old 03-20-2012, 06:52 PM
Sanji
toyomatt84's Avatar
Default Re: HELP PLEASE: Intermittent flickering lights- video inside
I would try adding a couple grounds to the block, to see if that would clear it up. If not, then I would take a look at the ground for the light housing (if its the only light flickering). If neither solves the problem, I'd look in to testing the alternator and possibly replacing it.
A good source for alternators would be NAPA, if you give them your core.
Old 03-20-2012, 07:24 PM
bk111's Avatar
Thank you. That is not the only light flickering, the headlights and dash lights do it too. Can the alternator be tested in car?
Old 03-20-2012, 07:57 PM
Sanji
toyomatt84's Avatar
Yup, and your local AutoZone or Advanced Auto Parts should be able to do it for free.
Old 05-24-2012, 11:57 PM
bk111's Avatar
Started doing it again, alternator tested out fine per oreillys. I have noticed one thing though. Everytime it starts doing it, I turn on the AC and headlights giving it a load, it stops and starts acting normally. Any ideas?
Old 05-31-2012, 02:13 PM
bin_dizzle's Avatar
check the underhood fuse box
Old 05-31-2012, 05:54 PM
eviee1973's Avatar
US market civics have an eld (electrical load detector) in the underhood fuse panel box, might be a source of the problem. Canadian market Civic's just have a metal strip bypassing where the eld would be.
Old 05-31-2012, 09:02 PM
rossijay's Avatar
Had a same problem ... Check the battery cables might have a shortage
vtecx2
02-14-2010 06:59 PM
accrdwgnguy
17
01-06-2009 03:24 PM
prophecy7115
03-08-2008 05:01 AM
Hawkrider
07-08-2003 02:53 PM
cjohnson_2
09-10-2001 04:19 PM
Quick Reply: HELP PLEASE: Intermittent flickering lights- video inside
