AC Compressor not working - Honda-Tech
Old 07-04-2012, 01:19 PM   #1
Default AC Compressor not working
My wife hit a deer a few months ago. Took a while to get the front bumper cover and hood replaced and when we put it back on the road the AC is not working. Here is what I know:
- The compressor is not coming on. The clutch disks do not start turning when the AC button is pressed.
- The pressure switch is made. The relay pulls in and the fans come on when the AC button is pressed, same as they do when I jump the switch.
- The relay is working.
- The gauge on the r134a refill kit goes into the red when I connect it to the low side (b/c the compressor is not coming on I imagine).
Any ideas as to what might be wrong or what to check next?
Thanks in advance for any tips.
lcifers is offline   Reply With Quote
Old 07-07-2012, 04:27 PM   #2
Pothole987's Avatar
Default Re: AC Compressor not working
check to see if you have power at the plug-in, its a chore to get at though. i just had this problem with my acura el ( same as civic ) i had power right to the pump and it ended up being the magnet for the clutch compressor. costly to buy new ( 1200) i ended up getting a used one as a barter.
Pothole987 is offline   Reply With Quote
Old 07-08-2012, 02:38 PM   #3
Did the condenser take a hit? Did it loose refrigerant? If there's no pressure in the system, the compressor won't come on.
MarkM01 is offline   Reply With Quote
AC not working, Hot Stickiness! Single-Cam Honda Civic / Del Sol (1992 - 2000) 16 02-10-2016 08:23 PM
A/C not working even after some test mugen94 Honda Civic (2001 - 2005) 3 08-03-2015 03:35 AM
no power to A/C compressor 1996 civic help bighoss77 Honda Civic / Del Sol (1992 - 2000) 2 01-28-2012 05:59 PM
Radiator Fan not coming on after A/C removal 92integraVTECgsr Acura Integra 3 03-17-2011 06:08 PM
No power to A/C compressor Ro-92 Honda Accord (1990 - 2002) 8 09-14-2005 06:47 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
