Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Has anyone ever heard this sound coming out of their car before?
Old 01-04-2013, 10:53 AM
SmallSteps3000's Avatar
Default Has anyone ever heard this sound coming out of their car before?
Honda civic EX 2003
What could this be? It sounds horrible
Jump to 01:12:
Old 01-04-2013, 02:38 PM
Sanji
toyomatt84's Avatar
Default Re: Has anyone ever heard this sound coming out of their car before?
Sounds like a heat shield is loose. Possibly an engine mount, as well.
Old 01-04-2013, 03:33 PM
meda215's Avatar
i agree with heat shield
Old 01-05-2013, 09:28 AM
lazlong's Avatar
Could be one of the pulleys.
Your valves are chattering pretty hard, definitely need a valve adjustment.
Old 01-06-2013, 07:36 AM
Rick hybrid's Avatar
it would be helpful if you would open the hood and record it again.
the mild ticking/clicking noise could be the fuel injectors which is normal.
the rattling noise could be the heat shield.
Old 05-16-2013, 02:22 PM
AMCCPO's Avatar
Was it your belt? Loose but noticeable?
Old 05-21-2013, 04:41 PM
joey2talk2's Avatar
mine had a cracked manifold.. apparently its pretty common on these civics...
Old 05-21-2013, 05:36 PM
EM2abe's Avatar
whelp. it could very well be the heat shield. but to me, it sounds like the latch/lever that you pull up when opening the hood. after i installed some motor mount inserts, my car makes that exact sound every now and then, at a certain RPM range (because of the stiffer mounts causing more vibration.).
Old 05-21-2013, 05:43 PM
SacredPRO's Avatar
Sound like a engine mount...
Old 05-22-2013, 02:26 AM
civico421's Avatar
Have it check by a mechanic to be sure
Hellzcivic
Honda Civic (2006 - 2015)
11-18-2006 09:44 PM
atmosphere
10-01-2005 04:14 PM
BlkEkCpe
07-10-2005 08:53 PM
Ol'SkoolDA9
08-25-2004 10:33 AM
JoeyBallzSI
10-10-2003 08:24 AM
Quick Reply: Has anyone ever heard this sound coming out of their car before?
