Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
5 LUG AND BRAKE SWAP INFORMATION: EM2, ES1 01-05
Old 10-12-2009, 07:36 PM
norcalem2's Avatar
Default 5 LUG AND BRAKE SWAP INFORMATION: EM2, ES1 01-05
5 Lug and Brake Swap EM2, ES1 01-05
This lug swap and brake conversion is for people still have D17 motor.
But if you want to put in a K series motor this works as well.
Parts:
-RSX Base knuckles, front
-RSX Type S Knuckes, front (use this only if you have a K swap)
-RSX Base or Type S / SI hatchback 04-05 “EP3” knuckles, rear
-RSX Base or Type S / SI hatchback 04-05 “EP3” Brake Caliper Rear
-RSX Base or Type S / SI hatchback 04-05 “EP3” E-Brake Cable
-RSX Base or Type S Brake Lines for each Brake Caliper (by new lines)
-RSX Base or Type S Brake Caliper (check seals)
-RSX Type S Front Brake Caliper brackets.
-"I also would suggest to swap out your brake booster for RSX Type S, Brake Master Cylinder, Brake Portioning Valve. This is also going to require a little rewiring of your brake lines to the master cylinder."
-By new Brake pads and rotors. (You can buy brand new OEM Brakes from ACURA which will cost you the most money, or go after market which are better for harsh driving I went with EBC pad and rotors).
EBC Model numbers:
Brake Pad Part Numbers: RSX Type S
Part # Description
DP41193R EBC High Friction Upgrade And Race; Disc Pads; Rear;
DP41254R EBC High Friction Upgrade And Race; Disc Pads; Front;
DP31193C EBC Redstuff Low Dust Superstreet; Disc Pads; Rear;
DP31254C EBC Redstuff Low Dust Superstreet; Disc Pads; Front;
UD537 EBC Ultimax Pad Set; Disc Pads; Rear;
UD829 EBC Ultimax Pad Set; Disc Pads; Front;
Brake Rotor Part Numbers: RSX Type S
Part # Description
USR7127 USR EBC Sport Rotor Kit; Front; 11.8 in. Dia.; Set of Two;
USR7128 USR EBC Sport Rotor Kit; Rear; 10.2 in. Dia.; Set of Two;
-5 lug wheels 5X114.3 pattern. Stock offset of our cars are +45mm Rims must bet at least 16” and larger to fit around the RSX Type S calipers.
FAQ:
Can I use parts from new SI Coupe or Sedan 2006-2010?
-New SI coupe and sedan 06+ parts do not bolt up with out modifying your car a lot. I would not suggest buying any of these parts. Except for the rims will work.
If you have an 01-02 you must change out your lower control arms!
-rsx front lower control arms(stocks can be modified to work by using tapered washers and taking up the slack)
if you have an 03-05 you dont need to modify the front struts
if you have an 01-02 you can either get the later style struts and knuckle bolts, or you can drill out the strut holes and use larger bolts
ABS System?
-If you have ABS I would suggest taking it out. It is a headache to make it work. If you want to keep ABS you are going to need the ABS system from RSX Type S with all the sensor and cables.
Why does the 01-05 Civic w/d17 need the RSX Base Front Knuckles?
-Well the RSX type s front knuckles/hubs, and cv joints do NOT spline to the civic axles, but the civic axles do spline into the base RSX Base Knuckles/hubs. If you want to use RSX Type S brake calipers and rotors you must gab the RSX Type S brake caliper brackets off the RSX type S knuckles. (Note: if you are going to use RSX Type S Brakes you must use 16” rim or larger)
AFTER YOU DO THIS LUG SWAP AND BRAKE CONVERSION TAKE IT TO A SHOP AND GET YOUR CAR ALIGMENT!
FIRESTONE TIRE SHOPS HAVE LIFETIME ALIGMENT AS LONG AS YOU OWN THE CAR. IT IS WORTH PAYING FOR THE LIFETIME ALIGMENT!
THIS IS ALSO POSTED ON SOCALCIVIC.COM
norcalem2 is offline
Old 10-12-2009, 08:03 PM
integraa972's Avatar
Default Re: 5 LUG AND BRAKE SWAP INFORMATION: EM2, ES1 01-05
Please sticky this!
Portioning valve, brake booster not needed but would be nice.
integraa972 is offline
Old 10-12-2009, 09:23 PM
katzenjammer84's Avatar
Nice writeup.
katzenjammer84 is offline
Old 10-12-2009, 11:28 PM
Plead da Fif
It Wasn't Me's Avatar
Added to FAQs
It Wasn't Me is offline
Old 10-13-2009, 11:38 AM
usnpr21's Avatar
-5 lug wheels 5X114.3 pattern. Stock offset of our cars are +45mm Rims must bet at least 16” and larger to fit around the calipers.
Wrong. 15" wheels can be used on base setup. Type S setup requires 16" wheels.
usnpr21 is offline
Old 10-13-2009, 03:44 PM
eghatch4sale's Avatar
I've been throwing this around back and fourth if I want to do this or not hmmmmm......
eghatch4sale is offline
Old 10-13-2009, 04:24 PM
Function>Fashion
Harlowe's Avatar
I'm running base rsx front knuckles with type S calipers & rotors. I didn't have to modify anything to get the calipers to fit, they bolt right up to the base hubs.
You don't NEED the RSX Type S Brake Portioning Valve either.
Nice write up though
Harlowe is offline
Old 10-16-2009, 03:50 PM
CivcaIh's Avatar
Nice work
CivcaIh is offline
Old 10-17-2009, 02:33 PM
jdm em2's Avatar
I want a 5 lug conversion anyone that is trying to sell one let me know pm me!!
jdm em2 is offline
Old 10-18-2009, 02:09 PM
tonykdee's Avatar
Are there going to be any advantages coming from our stock brake setup to the rsx type s in terms of performance?
tonykdee is offline
Old 10-18-2009, 06:33 PM
norcalem2's Avatar
There is a huge difference in stopping power as long as you go with the RSX Type S setup. If you go with the RSX base setup not that much.
Old 10-18-2009, 06:44 PM
Function>Fashion
Harlowe's Avatar
The base/ ep3 front rotors are the same size as stock em2 ones. Type s ones are 1.5" bigger
Harlowe is offline
Old 01-06-2010, 01:48 AM
em2k2's Avatar
damn so type-s front knuckles won't work if i have a d17.. but i can use base rsx knuckles with type-s rotor and calipers with some sort of bracket?
em2k2 is offline
Old 01-06-2010, 01:30 PM
Function>Fashion
Harlowe's Avatar
No special bracket is needed. Rsxs calipers bolt up to base knuckle/hubs
Harlowe is offline
Old 01-13-2010, 04:01 PM
rEM2's Avatar
So I plan on doing this but I want abs, for those who did the swap did you keep abs and if so what did you do to keep it?
rEM2 is offline
Old 01-14-2010, 12:48 PM
norcalem2's Avatar
My car did not come with ABS. So no I don't have it.
But as far as abs yes you can do it. Its just a pain in the *** if hook up thats all. If your car comes with ABS you just need the wires and sensors from the RSX to hook up to the knuckle.
If your car doesn't have abs you have to do custom brake lines from your master cylinder to your abs system and back to the portioning valve. plus the wires and sensors from the rsx to hook up to the knuckles.
Old 01-14-2010, 03:36 PM
rEM2's Avatar
I have abs on my EM2. So everything may be able to connect up with the rsx abs sensors? Hmmm I may have to buy them and try it out. A diy may ensue if it works out. I will not be trying until spring time ish.
rEM2 is offline
Old 01-14-2010, 07:29 PM
norcalem2's Avatar
Great when you do this post up pix and I will added it to this information guide. I will give you the credit for the abs hook up part.
Old 06-07-2010, 11:25 AM
mikey likes it's Avatar
Icon2 Re: 5 LUG AND BRAKE SWAP INFORMATION: EM2, ES1 01-05
So I'm kinda new to this And I'm sorry if someones already gone over this or not.
But I was looking at the DC5 type R big brake kit this guy has one for sale off of a 2006 RSX type R and I just wanted to know if it would fit? I have a 2004 civic EX Any help would be great! Thanks.
mikey likes it is offline
Old 10-28-2010, 10:23 AM
ccbl's Avatar
about to buy everything for this but missing the Base RSX front knuckles.....will you be okay with EP3 front knuckles from 02-04 with everything else from the Type S RSX (hubs, calipers, rotors?
basically i have the full type S swap but i cant use the type s knuckles so im scouting for base RSX ones.. just wanted to know if i could use the ep3 ones
ccbl is offline
Old 10-28-2010, 04:21 PM
Sanji
toyomatt84's Avatar
01-03 EP3's were 4x100, not 5-lug. 04-05's were 5x114.3, and can be used.
toyomatt84 is offline
Old 10-28-2010, 06:18 PM
ccbl's Avatar
^ thanks.. i got my parts mixed up.. i thought the knuckles were separate from the hubs (which i thought determined the 5 or 4 bolt) .. so then i'd just slap the hubs of the type s onto the ep3 knuckles or something.. haha i dunno what i was thinking... thanks for clearing things up.. sucks we can't use the type s knuckles.. scrambling for base ones is not easy
ccbl is offline
Old 10-29-2010, 12:31 AM
Sanji
toyomatt84's Avatar
If you had a K-series engine, it wouldn't matter which knuckle you bought, as long as all the parts matched (axles, knuckles, and hubs).
Old 11-03-2010, 09:52 AM
Honda Sebas's Avatar
could we still use the type-s knuckles/full type-s swap even if we do not have a k-series
Because i still have the stock d17a2 motor, but i'm planning to drop a K24a2 next year.
Honda Sebas is offline
Old 11-03-2010, 12:45 PM
Sanji
toyomatt84's Avatar
A little reading goes a long way.
Quick Reply: 5 LUG AND BRAKE SWAP INFORMATION: EM2, ES1 01-05
