4 door, rear door handle removal
So my rear door handle on the passenger side seems to be let go from the 2 bolts that hold it in place. However it doesnt look like it was ever attached to the bolt heads, looks like they juct snap down over the top of the bolt.
Anyway i've tried searching and i havent found anything to show how the handle is actually installed.
does anyway have a Guide on how to replace the door handle on the REAR door
BTW: this is for the exterior handle not interior
Re: 4 door, rear door handle removal
If you remove your door panel and the plastic barrier behind it, you can see what you'll need to do. A couple screws, connecting rods and nuts ... voila!
Hopefully someone has a diagram. Trying to explain what everything looks like and where it is would probably end up creating problems. Hahaha..
GSlowR
01-27-2002 06:15 PM
