2005 t.s.x. motor and trans will it fit into a 2001 civic coupe si
I bought a 2005 t.s.x. motor and trans and found out through the blogs that i need a r.s.x. trans .Is this true or is their a way to put the whole engine and trans into my civic si . I also know where to get t.s.x. k24a2 motors if anyone is looking.
Re: 2005 t.s.x. motor and trans will it fit into a 2001 civic coupe si (nitrothis)
If your civic is the si/ep3 you will need to ask that in the forum for that particular model
https://honda-tech.com/zeroforum/32
Sanji
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nitrothis »</TD></TR><TR><TD CLASS="quote">I bought a 2005 t.s.x. motor and trans and found out through the blogs that i need a r.s.x. trans .Is this true or is their a way to put the whole engine and trans into my civic si . I also know where to get t.s.x. k24a2 motors if anyone is looking.</TD></TR></TABLE>
You'll need a K20 transmission, whether it's a 5-speed from a K20A3 or a 6-speed from a K20A2 or K20A. The transmission housings are different, and have different mounting brackets, when compared to the K24's.
Re: 2005 t.s.x. motor and trans will it fit into a 2001 civic coupe si (toyomatt84)
where can you get these k24's from?
Function>Fashion
Re: 2005 t.s.x. motor and trans will it fit into a 2001 civic coupe si (AR_motorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AR_motorsports »</TD></TR><TR><TD CLASS="quote">If your civic is the si/ep3 you will need to ask that in the forum for that particular model
EP3s wern't produced in 2001, and they def weren't coupes..
You'll need a transmission from an rsx or ep3, as stated
(Harlowe)
Harlowe...as stated above he has a Canadian Market 2001 Civic Si coupe (same as US Market EX Civic EX Coupe.)
...just for clarification for anyone else skimming this thread
Grace Under Pressure
Re: (Harlowe) (Nighthawk7thGen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nighthawk7thGen »</TD></TR><TR><TD CLASS="quote">
...just for clarification for anyone else skimming this thread </TD></TR></TABLE>
I'm skimming.
I'm skimming.
etank82
05-31-2008 07:52 PM
