Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
02 civic unstable/unsafe to drive at 40+mph?
Old 07-31-2010, 10:41 AM
redlobster's Avatar
Default 02 civic unstable/unsafe to drive at 40+mph?
Brother Sold it, delete please
Old 07-31-2010, 11:09 AM
lazlong's Avatar
Default Re: 02 civic unstable/unsafe to drive at 40+mph?
Check swaybar links, ball joints, and tierod ends
Old 07-31-2010, 01:29 PM
redlobster's Avatar
Old 07-31-2010, 01:42 PM
Mickeeezy's Avatar
That, and also make sure the wheels are all balanced correctly. You'd be surprise how big of an impact that has on your car. Is the car lowered? Could be camber/caster/toe
Old 07-31-2010, 04:14 PM
lazlong's Avatar
Originally Posted by redlobster
I will, is there easy ways to check each?
Look and see if the boot is worn or cracked. Jack up the wheel and wiggle the tire. If there's any up/down movement it's the ball joint. Back/front wiggle is tierod end.
Old 07-31-2010, 11:09 PM
portaman03's Avatar
Im almost certain that your lower control arm bushings aka compliance bushings are shot.
I say this because mine were, and the front end wandered all over the road too.
Jack up the car and check out the front lower control arms. There is a busing the lies horizontally towards the inside, its connected to the subframe.
https://honda-tech.com/forums/showth...ght=compliance
Old 08-01-2010, 08:23 AM
redlobster's Avatar
Old 08-01-2010, 08:24 PM
krans's Avatar
Portaman is right most likely the compliance bushings are shot..
To check just turn your wheels to either side and look inside the wheel well towards the front of the vehicle you cant miss it.
goodluck
Old 08-01-2010, 08:51 PM
Plead da Fif
It Wasn't Me's Avatar
Wouldn't bad compliance bushings be accompanied with a clunking noise while driving or speedbumps and road imperfections?
I remember reading something about it, but haven't experienced problems with my compliance bushings, yet. YET!
Old 08-01-2010, 08:59 PM
suds1485's Avatar
yes you are right. ball joints will clunk also mainly when turning though
Old 08-02-2010, 08:56 PM
portaman03's Avatar
Mine didnt clunk, probably because they were torn but still physically there. They just caused some serious play and wandering in the steering.
Old 08-02-2010, 09:04 PM
Pothole987's Avatar
just turn the wheels and look at the front of the control arm and look at the bushing if its fallen out, torn or not there that would be your problem.
Old 08-02-2010, 09:38 PM
servedchilled's Avatar
i had the same problem..replaced those bushing and its completely back to its old ways.. theyre like 17$ a pop at honda dealership
Old 08-02-2010, 09:46 PM
Plead da Fif
Ah, it wasn't you that I was thinking of then.
I vaguely remembered someone making a thread complaining of clunking noises, then later posting a picture of their front LCA with the total absence of bushing material. I hadn't seen anything quite like that before. LOL
Old 10-17-2010, 06:51 PM
redlobster's Avatar
Old 10-17-2010, 09:39 PM
portaman03's Avatar
You can buy Energy Suspension compliance bushings online. But, you have to have them pressed im by a mechanic.
Some people are choosing to purchase front lower control arms on ebay. Ive done this and installed them myself. It cost the same amount as if I would have bought just the bushings and had a mechanic do the work.
Old 10-18-2010, 03:41 PM
redlobster's Avatar
Old 10-18-2010, 04:04 PM
integraa972's Avatar
Mine is doin the same but it feels like the back end end is wandering. What can it be?
Old 10-18-2010, 04:40 PM
E-Money's Avatar
Old 10-18-2010, 05:25 PM
portaman03's Avatar
I was checking prices as well, I can get both left and right front control arms for about $100 shipped on ebay. I have never installed lower control arms, is it something I could do relatively easy at my house?
You can do it in an afternoon.
Search these forums for the instructions, there should be a writeup, check the faq's and search feature.
Old 10-18-2010, 09:35 PM
redlobster's Avatar
Old 10-18-2010, 10:49 PM
Plead da Fif
Is there any noise associated with it? Any roaring or knocking? Anyway, just have a look at the rear suspension components and their bushings. It's pretty basic stuff, so if something is worn it will be easy to notice.
Old 10-18-2010, 10:50 PM
Plead da Fif
how do they look to you guys?
Dirty, but otherwise okay.
Old 10-19-2010, 01:08 PM
portaman03's Avatar
Bushings look okay. I would check the tie rods next.
Old 10-19-2010, 02:17 PM
TailZ's Avatar
yeah bushings look fine.
my car wanders a lot on freeways too.
Quick Reply: 02 civic unstable/unsafe to drive at 40+mph?
