2005 Honda Civic Code to reset radio - Honda-Tech
Old 05-08-2010, 08:28 AM   #1
Default 2005 Honda Civic Code to reset radio
I have been through the motions to retrieve the 4 digit code from Honda's website by proving ownership with VIN#, Navigation#, Radio# etc and they issued me the 4 digit required to reset the system after a battery disconnect.
So that part is done but I do not know what to do with the numbers given to me.
I read other post from different forums that said to
1. turn on ignition switch but not start the engine.
2. turn on the radio and of course you see "COdE"
3. use the manual tuning **** for prompts to enter the codes.
Doesn't work.
Also read where someone said to disconnect the battery again for 15 minutes
and start fresh with codes entry.
Can anyone enlighten me.
pebbles99 is offline   Reply With Quote
Old 05-09-2010, 08:54 PM   #2
jdmhondaes1's Avatar
Default Re: 2005 Honda Civic Code to reset radio
steps 1 and 2 are right but 3 isn't. at least for my car that's not right. after it says "Code", just hit the corresponding number button on the actuall radio. after you hit all the right button numbers, the radio will beep to let you know you activated the right "code"
jdmhondaes1 is offline   Reply With Quote
Old 05-10-2010, 12:44 PM   #3
Not sure about the regular radio/CD player, on the 6 CD changer you enter the code using the number you use to select the stations/CDs.
husyk is offline   Reply With Quote
Old 05-15-2010, 12:15 PM   #4
Well if you have the code.
1. push the number (it should pop up by the "code")
2. Put in the next corresponding numbers.
When i went to honda they said when you lock it up you'll have to wait 15minutes to try again.
drbrbhoy is offline   Reply With Quote
Old 05-15-2010, 01:42 PM   #5
20-EM2-05's Avatar
Did you have the Manual for the car? If you do it should be on the first page of the manual. Should say "Radio Code: (4 Digit numbers).
Always have mines handy incase I kill the battery.
20-EM2-05 is offline   Reply With Quote
Old 05-15-2010, 10:40 PM   #6
DynastyRacer22's Avatar
1-5 radio presets to enter / if error message appear & locks up radio, then you need to disconnect neg- battery terminal for 2 minutes
DynastyRacer22 is offline   Reply With Quote
Radio Code Error bal Odyssey | Ridgeline | MDX | Pilot | RDX | HR-V 0 04-03-2016 08:12 PM
Radio code doesn't work michla77 Honda Accord & Crosstour (2003 - Current) 1 05-26-2008 04:22 PM
radio trouble on 2000 civic...help iluvmy2000civicex Honda Civic / Del Sol (1992 - 2000) 14 06-05-2006 08:22 PM
Disconnected Battery, Need 5-digit code for radio fso_BamBam Acura Integra Type-R 10 07-09-2003 04:56 PM
Stock radio code? Viorent GRIP! Honda Civic / Del Sol (1992 - 2000) 1 11-18-2002 01:46 AM
Tags
2004, 2005, 2006, battery, cd, civic, code, disconnect, honda, hybrid, pilot, radio, reset, steps, type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
