Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
02 Honda Civic P0420 code
Old 02-06-2012, 06:27 AM
jasrams's Avatar
Default 02 Honda Civic P0420 code
My car threw this code and I know it has to do with the cat perfroming below threshold. My question is can I replace the cat with an aftermarket resonator and place the o2 sensor in the resonator. please advise!/
Old 02-06-2012, 09:14 AM
Whatislove's Avatar
Default Re: 02 Honda Civic P0420 code
I had the same problem. I replaced mine with a $50 magnaflow cat which then continued to give me that same error code. So I installed a spark plug non-fouler and that solved the problem. I recommend you do this.
These cars are ULEV so they require that california/carb certified $700 cat
Old 02-07-2012, 02:03 AM
lowlife9's Avatar
this
http://www.robearracing.com/pd-megan...or-cel-fix.cfm
Old 02-07-2012, 05:18 AM
Whatislove's Avatar
^^that's pretty much what a spark plug non-fouler is with an added 90 degree angle and $25 more dollars.
Old 02-07-2012, 05:01 PM
Allboost18b's Avatar
The only problem with putting an obd2 sensor into a resonator is that it will kill gas milage. Remember that cats filter the co2 from the exhaust and o2 sensor see how much and how clean the fuel is burning. Generally the problem if an o2 sensor is reinstalled after going bad means its choked full of carbon buildup... Generally i replace with new sensors everytime a cats put on ( if its running the code) although it's not necessary...
Old 02-07-2012, 08:47 PM
seanbev24's Avatar
^^ The downstream o2 sensor has absolutely no effect on gas mileage. It's only job is to monitor cat efficiency.
Old 02-07-2012, 08:56 PM
Whatislove's Avatar
I would like to say that's not true. When I had mine 0420 error and before I installed the non-fouler I was getting worse gas mileage.
Old 02-07-2012, 09:50 PM
seanbev24's Avatar
I imagine that was because of the PCM's reaction to the p0420 code. If the sensor actually controlled air/fuel ratio, the non-fouler trick probably wouldn't be an option. I know some newer cars that have wideband systems use the downstream sensor to fine-tune air/fuel, but in standard systems the downstream is just monitoring the cat.
Old 02-08-2012, 05:22 AM
He wanted to omitt the cat bud.. And glasspack, instead with the sensor into it. Glasspack/resonators in general only filter noise, cats filter exhaust for emissions. If you just run the sensor after a ressy without a cat, thatsensors goin to get a serious beating wideband or not.... And the second o2 sensor reads the exhaust, which the ecu reads as do i need a little more gas or little more air from what youre telling me, the fact theres 2 on 02 lx's obd2 <-- will mean that it has an effect but not so much as it would if there were only 1. Truthfully, given that an engine is a self running air vaccum, i try to leave the o2 sensors how they are, and when boosting cars i consult a tuner first to see how they affect my engine directly.
Remember this is a fourm, im offering an opinion mixed with my own belief and experience. Weather you follow it or agree with it, is your own choice.
lxdriver
06-07-2013 10:58 PM
scott_turner
04-30-2011 04:14 PM
Si_chRis
29
06-22-2009 12:56 PM
janek
11-03-2008 02:25 AM
nutball72
08-10-2007 03:05 PM
Quick Reply: 02 Honda Civic P0420 code
