2004 civic lx manual transmission installation - Honda-Tech
Old 09-11-2009, 12:13 PM   #1
Default 2004 civic lx manual transmission installation
This is... from a newbie that was damaged and tossed around by Honda... and decided to take his car back and buy a used trans and install it himself with some friends...
What type of special out of the ordinary tools will I need? Anything needed for the fly wheel?
What about to align the clutch?
I am currently going to a yard to buy a 2002 honda civic lx manual trans.. I believe this will go into my 2004 civic lx..
Any advice? I just bought the Helms...
Many Thanks!
mytrangtrai is offline   Reply With Quote
Old 09-13-2009, 01:26 PM   #2
jdmfreak1992's Avatar
Default Re: 2004 civic lx manual transmission installation
You won't need to worry about alining the clutch or any tools for the fly wheel unless your changing the clutch/fly. But depending on how hard you drive your car and how many miles are on it if you have the tranny off you might want to replace the clutch. If you do you will need a clutch alinement tool. As far as removing the tranny I'm guessing just your basic hand tools socket set/torque wrench. I haven't dropped any out of a this gen civc but I have out of others and they all seem similar. I would suggest if your doing it at home that you have an extra set of hands to help you and pick up a copy of the Shop Manual just incase you get stuck and don't know what goes were that can be a real life saver.
jdmfreak1992 is offline   Reply With Quote
Old 09-14-2009, 06:56 AM   #3
03EM2guy's Avatar
ive pulled the tranny on my 03 ...i would recomend while its out do a clutch kit (w/ release bearing, pilot bearing) the only thing i would add to ^^^ is the ball joints on the lower control arms (you have to drop the subframe) ...so a ball joint puller
03EM2guy is offline   Reply With Quote
Civic 2004 spark plugs narab123 Honda Civic (2001 - 2005) 7 10-01-2012 12:30 PM
what trans can i use 2004 honda civic trans Quinn1387 Honda Civic (2001 - 2005) 2 08-26-2011 11:10 AM
2005 Civic LX MLBosley410 Honda Civic (2001 - 2005) 4 01-19-2010 08:04 AM
2004 Honda Civic LX MAP sensor wires. DXR Tech / Misc 2 07-19-2008 10:52 PM
02 civic lx manual trans swap hxcmech Honda Civic (2001 - 2005) 1 03-17-2007 08:36 PM
Tags
2002, 2004, civic, honda, install, installation, installing, lx, manual, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
