2004 Civic, CAN'T FIND TRANSMISSION DRAIN PLUG - Honda-Tech
Old 06-01-2007, 11:28 AM   #1
TheJellyRoll's Avatar
Default 2004 Civic, CAN'T FIND TRANSMISSION DRAIN PLUG
I've changed transmission fluid many times in other cars. I found out that there is no pan, no filter. I just need to pull the plug and go from there. Well, I looked everywhere and I can't find the Drain Plug. If someone can help I'd be very greatful.
TheJellyRoll is offline   Reply With Quote
Old 06-01-2007, 03:05 PM   #2
Default Re: 2004 Civic, CAN'T FIND TRANSMISSION DRAIN PLUG (TheJellyRoll)
OK I found a plate that had 2 bolts holding it in. Undernieth there is a gold thing sticking out with a small screw on it. It looks like its connected to something I don't want to mess with, but is this what I'm looking for. I'm new to this car and I don't want to break anything. Please Help.
Old 06-01-2007, 03:28 PM   #3
fventura03's Avatar
not sure if it's the same on an auto (not sure what you have, auto or manual) but on a manual here's the bolt you need to remove circled in white, at the bottom - this is for an older civic, so it won't be at the same location for your car - just look around:
fventura03 is offline   Reply With Quote
Old 06-01-2007, 03:30 PM   #4
fventura03's Avatar
a bit more help:
this is what the fill plug looks like:
and the drain:
how did i find this? i searched the archives for "transmission plug"
Old 06-01-2007, 11:20 PM   #5
03EM2guy's Avatar
Default Re: (fventura03)
fyi ...manual's dont have a filter...
03EM2guy is offline   Reply With Quote
1996 Honda Civic auto transmission drain mcd7 Honda Civic / Del Sol (1992 - 2000) 8 10-06-2011 11:52 AM
I cant find my coolant drain plug? Redprelude98 Honda Civic / Del Sol (1992 - 2000) 24 07-10-2009 11:13 AM
Fuel Sump Using Fuel Tank Drain Plug? Tchleung Forced Induction 2 09-24-2008 02:31 PM
Can't find the Transmission Drain PrettyFastRide Honda Accord (1990 - 2002) 5 01-07-2007 06:47 PM
Wheres the drain plug for the water on the b18c? mac_24_seven Acura Integra 10 04-03-2006 05:55 PM
Tags
01, 04, 2001, 2003, 2004, 2005, 2007, civic, drain, honda, located, location, plug, tranmission, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
